| Headphone Systems Everything to do with Headphones |
#2991 | |
With a 12VAC transformer you'd probably measure somewhere near 20VDC across either diode.....but it's actually not a constant DC you're measuring. For troubleshooting the power-supply section of the O2, best to attach a DVM black lead on the ground point and move around with the red lead. (Power switch in the off position.) It should be easy to find the malfunctioning component. Cheers, Dave. |
#2992 |
Hello everyone, I got a problem when I try to build my second O2 AMP, when I plug the new O2 with AC power, the voltage across BT1 is 12V, but the voltage across BT2 is 21.3V I read these numbers while the SW1 is off.
Does this means there are some issues with U6? |
#2993 |
Okay. I don't want to disagree with anything in your post.
But you're directing it to the wrong guy.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#2994 | |
#2995 |
#2996 |
Whoops.
randomlf's post above has a good point. I was assuming the O2 didn't have batteries, but re-reading your post I see it does. Things get more interesting with batteries. I'll change my guess from a dead regulator chip to a damaged battery and possibly one or more dead op amps. Would be good to test your headphones too on a known good source to make sure there is no DC damage.With batteries installed a tip-positive DC adapter would still power the positive rail by the action of the O2's diode logic, and charge/maintain the positive rail battery, with the U5 regulator running in dropout. But now the negative rail would be held up by the negative battery until it discharges to the point where the power management circuit trips the mosfets and shuts the whole thing down. But the PM circuit wouldn't pick up on the fact that positive rail is on AC and the negative rail is on batteries, since it just looks for a minimum of 14Vdc across both rails combined. So the first problem here is that the O2 PM design assumes both batteries are discharging more or less equally. In this situation if the positive rail is at 11Vdc or so, the negative battery would get down to 14Vdc - 11Vdc = 3Vdc which is enough to permanently damage it. Generally 0.9Vdc per cell is considered the minimum for NiMH it seems, and this would be 3Vdc/7 = 0.42 per cell. The second problem is that a pretty unbalanced set of rails would be presented to the op amps. Maybe starting out at +11vdc/-9.5Vdc and going down to +11Vdc/-3Vdc at the point where the PM circuit trips. For small imbalances the maximum AC swing on the op amps is just affected, clipping against the lower voltage rail first. But for that much rail imbalance (+11/-3) it could start affecting the DC bias of the op amps. I kind of doubt it would kill them although it is possible if the common mode input voltage range gets exceeded and they latch up in some fashion, but it could very well produce a high(er) DC offset on the output, which may have made out to the headphones. All of this is reversed, of course, for a tip-negative DC adapter. Then the positive rail battery might be damaged. The good news is that the regulator chips probably did survive if there were batteries in place. The negative rail battery would have prevented the negative regulator from seeing a reverse voltage. I also don't see any path in all of this for damaging the mosfets, unless one of the output NJM4556 chips or the NJM2068 chip happened to dead short. So the first thing to check is still those voltages out of the regulator chips on D1 and D5 to make sure the AC supplies are working OK. Then I would be inclined to just put a finger on each of the op amps to see if any are heating up excessively. Then measure the DC offset on the O2 outputs and see if it is much higher than the typical 3mV. Last edited by agdr; 5th January 2013 at 05:00 PM. |
#2997 |
I finished my O2+ODAC build last night. Many thanks to Stefan at Headnhifi for supplying the parts and answering all my queries promptly!
At the end of my build, when I was wiring up the ODAC inside the O2 case, I had a lot of trouble with the wiring. My initial wiring was too bad, but upon realising that the CAT5 I had cut was too short, I had to remove them and make new lengths. When I removed the wire from the ODAC, the holes were filled with solder and nothing I could do would remove it. As a result, I had to solder them 'on top' of the holes. It's a bit of a hack job but it works (but): is it possible that a poor connection would result in a slight channel bias? I can't be 100% sure but I am fairly certainly that music playing on the left channel on my headphones is louder than the right? If one ground was less secure, could this also cause it? I've tested with two headphones: Sennheiser HD580 and Takstar HI2050. Using the left cup on my right ear on both headphones rules out that I have slightly poorer hearing in one ear. As a side note, any tips for removing the solder from the holes? I might delve back in and try and redo the holes. I would really appreciate any photos that anyone has of the ODAC -> O2 connections. All the photos I have seen of build leave this step out for some reason! |
#2998 |
Hey guys-
In my upcoming O2 build I want to have a pass thru to another device. The O2 will be part of my stereo/tv setup, between my source (dvd player) and EQ. I don't use a preamp. So, the signal needs to go into the O2, but it needs to also go to the EQ. This way we can choose to use the O2 or not, or use it in addition to the rest of the stereo equipment. This happens sometimes because, for instance, one of us likes to watch movies using the headphones while the other person listens to the speakers. So, is it OK to just parallel connect a second pair of RCA connectors with the O2 inputs to route the signal to the EQ? Without additional circuitry or negative impact? Also, on occassion we will want to use two (very different) headphones at the same time. Can you recommend a simple circuit to add that will enable me to use two very different headphone simultaneously with the O2 output? I would switch this splitter/buffer so it's isolated when only one pair of headphones are being used (the normal case), since obviously I can't optimize the O2 for more than one set of headphones ![]() Thanks, Keith Ostertag |
#2999 | ||
You can listen and see if you can hear any difference, but the only difference should be a slight drop in volume. Quote:
Suppose the EQ has an input impedance of 10k (a common enough value), this will make the parallel input impedance (of all three devices) 3k3, which most sources will still drive without problem. Input impedance in audio is usually targeted to be 10* output impedance as a rule-of-thumb, but that is a rough rule-of-thumb. As long as the input impedance doesn't fall below the output impedance, it'll be pretty much OK. |
#3000 |
OK, thanks very much!
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
