Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 6th November 2012, 01:03 PM   #2881
qwertz is offline qwertz
Hello!
I am very interested in what is your opinion about changing:
-NJM4556AD to LME49720HA (TO99 package, better sound than NA, MA package)
-NJM2068D to OPA1612AID.
Anyone has tried these opamps in The Objective2 ?
Old 8th November 2012, 02:12 AM   #2882
dewasiuk is offline dewasiuk  Canada
Just checking in to see if anyone has heard from RocketScientist lately? He hasn't posted on his blog comments for a long time either.
Old 8th November 2012, 09:45 AM   #2883
aphocus is offline aphocus  New Zealand
Been running my O2 for a while now, and everything seems to be working fine and all measurements came out correctly.
Yet today I ran my batteries flat for the first time and I heard some extremely loud popping which I can only figure being it power cycling I have the revised board with the lower ohm Resistors, so I assume this modification hasn't helped.
Could someone offer me some advice on how to fix this, it was rather loud, far louder than power on/off transients, I'm worried it could ruin my headphones.
Thanks.
Old 8th November 2012, 10:25 AM   #2884
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Turn off the O2 and recharge the batteries.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 8th November 2012, 06:26 PM   #2885
No I'm just going to keep listening to the loud popping and hopefully ruin my headphones...
Seriously, is there no way to make it power off properly?
Old 9th November 2012, 02:47 AM   #2886
fubar3 is offline fubar3  Canada
Default O2 unstable with weak battery
Replace the fixed 12v regulators with something like LM317. Build circuit like "remote shutoff" in the datasheet example and then add a comparator to that. When batteries drop assert the remote shutoff. You might also need a relay so that "off" latches somehow.
Old 9th November 2012, 01:28 PM   #2887
agdr is offline agdr  United States
agdr's Avatar
If anyone would like to test a "fix", swap R9 for a 30k resistor and R25 for a 620k. You can do it without removing the existing resistors by just soldering a 1.0 meg ohm resistor across the existing 1.5 meg R25 on the back of the PC board, then solder a 330k resistor across the existing 33k R9 on the back of the board.
Use 1% resistors, or if using 5% test a bunch of them with DMM to find a couple close to the real value. Wattage doesn't matter for this, anything that fits works.
What you are doing is raising the voltage the batteries have to rise up to on their own again, once the O2 power management circuit turns off, to 1.35Vdc per cell or 9.45Vdc per battery, above the nominal 1.2Vdc but still less than the 1.45Vdc per cell or 10.15Vdc fully charged level.
The change should stop the oscillation entirely when the PM circuit shuts down, or at least slow the period way down.
Old 11th November 2012, 09:18 PM   #2888
wiinippongamer is offline wiinippongamer
Thanks.
Curious on how many people have experienced this same issue. Mine's a recent build by JDSlabs, I'm using some t50rp's and vintage ortho's which are f-ing indestructible but if I had some sensitive IEM's I'd definetly be concerned about it damaging them. only happens maybe 2% of the time to me after the batteries drain though.
Old 12th November 2012, 05:05 AM   #2889
availlyrics is offline availlyrics  India
availlyrics's Avatar
Originally Posted by qwertz View Post
Hello!
pls read this first NwAvGuy: Op Amps: Myths & Facts
Old 12th November 2012, 07:17 AM   #2890
Zoide is offline Zoide  United States
Anyone? Is NwAvGuy OK?
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
