Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 23rd August 2012, 05:48 PM   #2761
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Originally Posted by everlong View Post
Might be smart!
This is my solder station: AOYUE 936 Anti-static Soldering Station soldering tool | eBay
Aoyue 936 Solder Station Variable Temperature Control | eBay this is the same? Buying from America wont happen, shipping costs way too much. But ebay.co.uk is OK and also amazon.co.uk
My audio and DIY blog: http://phimusic.blogspot.se/
Old 23rd August 2012, 05:54 PM   #2762
everlong is offline everlong
Yep, looks the same!
Old 23rd August 2012, 05:57 PM   #2763
Rullknufs's Avatar
It was cheap, that's for sure. Is it temperature controlled?
Old 23rd August 2012, 10:03 PM   #2764
ctrefzer is offline ctrefzer
I have the same model, the 936 is quite alright but it is really essential to keep the tip clean and freshly tinned, as with every iron I suppose. There is temperature control, albeit via an analog dial, and I can hardly tell whether that is all too accurate. Over time I got used to various settings depending on the task at hand.
There is a newer model with digital temperature control. Those have a reputation of tighter regulation, i.e. once you touch a large mass of copper with the tip it will quickly react, whereas the analog counterparts have a much larger temperature drop before they turn the heat back on. One is easily tempted to dial in a higher temperature, which is not always too healthy for the more sensitive parts involved. For casual use and ordinary PCB work though, the 936 is really good value and leaves not much to be desired.
Kind regards,
Chris
Old 25th August 2012, 02:16 PM   #2765
ritsute is offline ritsute
Could someone help take a look in here? i have some issues with my o2
http://www.diyaudio.com/forums/headp...rd-issues.html
Old 26th August 2012, 04:49 AM   #2766
dewasiuk is offline dewasiuk  Canada
Originally Posted by Francois G View Post
Thanks, I follow you reasoning. Best wishes and do share if all works out well.
Thanks! First step would be to gather component footprints and exact board dimensions of the existing O2 project if RocketScientist or anyone else has them and start to modify and add new footprints for an SMT version. After that, I can simply re-create the schematic and annotate it into a PCB project using Altium's software.
Old 29th August 2012, 09:51 PM   #2767
Rullknufs's Avatar
Oh, a silly question.
I have removed the gain resistors for a 1x gain, but is there any way to get even less gain?
For low level evening listening I still find myself having the volume control all way to the bottom almost which means I get a little channel imbalances.
Old 29th August 2012, 11:58 PM   #2768
agdr is offline agdr  United States
agdr's Avatar
I have removed the gain resistors for a 1x gain, but is there any way to get even less gain?.
Here: O2 amp CRC, diode, cap, and heatsink mods
Old 1st September 2012, 12:18 AM   #2769
Yangoran is offline Yangoran  United States
Send a message via AIM to Yangoran Send a message via MSN to Yangoran The Objective2 (O2) Headphone Amp DIY Project
I've started a crowdfunding project for some nice SS front panels if anyone is interested.
Objective2 Headphone Amplifier Stainless Steel Front Panel -- Indiegogo
Old 1st September 2012, 02:26 AM   #2770
6L6 is offline 6L6  United States
6L6's Avatar
I love the idea!
I bought one, and hope that more of you do the same to make this great idea a reality!
Come on, everyone, support the community!!
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
