The Objective2 (O2) Headphone Amp DIY Project - Page 275 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 22nd August 2012, 05:10 PM   #2741
Higher(what I think) ohm to reduce gain, but don't know what the value you should choose.
Old 22nd August 2012, 06:25 PM   #2742
VJK is offline VJK
@Rullknufs : Glad that you got everything working . Yes you can use the ports on the monitor. I use the ones on my Dell 2711. I assume you are using a very sensitive earphones if you are getting high volumes on the default low gain resistors (1K OHM); technically then you don't need an amp BUT it is indeed a good idea to use the amp as the interface offers a better output impedance. You could go for a 1X gain by omitting (or cutting one end of each if you have soldered them to the board) both R17 and 21. Read more about here : NwAvGuy: O2 Details under Gain settings
Last edited by VJK; 22nd August 2012 at 06:40 PM. Reason: Adding link to the original Article/blog.
Old 22nd August 2012, 06:46 PM   #2743
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
Thanks.
I'm using a pair of Denon AH-D2000 headphones.
My audio and DIY blog: http://phimusic.blogspot.se/
Old 22nd August 2012, 08:12 PM   #2744
Hi guys I thought I'd show you my first experiment for the O2 front face, also I have been working on a face for the CMOY by JDS labs. Dont worry about the colours it was just some I had left over, they have been resin cast. The clear one has problems with bubbles this is normal but because there are other things like the watch parts in it, it makes them 10 x worse, however I have a pressure chamber on its way which should make the bubbles so small you cant see them. Also the clear resin takes about a week to cure to rock hard and I could'nt wait and i dropped it and snapped off an end . I have just 30 mins ago bought a CNC Milling machine ( Hobby Size) and thats when I going to make the full enclosures , either soft metals or hard, wood and milled resins. Hope u likeey
Old 22nd August 2012, 08:31 PM   #2745
Rullknufs's Avatar
That's my O2 amplifier + ODAC. For more pictures and text see ?music
Old 22nd August 2012, 10:26 PM   #2746
Rullknufs's Avatar
Found something VERY interesting... Seems like my amplifier is running mono-mode?
Did some channel tests now and left channel and right channel sounds similar. Maybe that's why the music sounds so different...
When I was soldering the wires to connect the ODAC to the O2 I was a bit confused when following this guide -> http://www.headnhifi.com/components/...To_O2_ODAC.pdf
If you look at the second way, the switched version (page three) you see the white wires going to left and right while the black ones go into the same hole, right? That's how I've done too. Then in the next picture you see the black wires going to what seems to be left and right while the white goes in two other holes.
That is how I have connected it, as it was in the guide I followed. it felt very weird but since I'm a beginner I thought it might be best to follow the guide.
Is the guide wrong and that's why I have only mono sound or is there any other reason?
Old 23rd August 2012, 01:09 AM   #2747
agdr is offline agdr  United States
agdr's Avatar
I haven't bought an ODAC, and your link isn't working (looks like that site requires registration and login), but I think I see the problem. You have the black and white wires reversed. Black is usually color coded for ground. The ground wires should go in those two holes that are NOT marked L and R, the rightmost ones in your photo, from the writeup under the first photo on RocketScientists ODAC tech page: http://nwavguy.blogspot.com/2012/05/...ay-update.html . The ODAC PCB will likely connect those two wires together. RocketScientist probably just has the two ground wires split out like that so field cancellation (no noise pickup) works properly when each is twisted together with a signal wire. The white wires are probably the signal wires. If so those DO go in the holes marked L & R.
If my assumptions are right, what is probably happening is the ODAC PCB is connecting those two white wires together, which means it is connecting the left and right input channels on the O2 together, which is why you are getting mono. The two ground wires are connected together back at the O2, which would complete the mono circuit and short the ODAC outputs together. I would guess the ODAC has a pretty high output impedance, looking back in to the circuit, so shorting the ODAC outputs together probably hasn't damaged anything, but rather formed a "mixer" circuit that is combining the left and right channels.
Old 23rd August 2012, 07:03 AM   #2748
swalter is offline swalter  Switzerland
life is beautiful...
How many watches did you have to kill for that panel??? to get rid of the bubbles when playing with resin I used a home made vacuum chamber. A bucket or something connected with a hose pipe to an y piece, then a hose pipe connected to the tap. The streaming by water sucks out the air from the bucket (sealed with playdo or something the like to a glass surface). This sucks out the bubbles quiet well. But careful, the vacuum can get really high very fast and suck your seal in
everything O2 and ODAC related can be found here: www.headnhifi.com - your DIY and audio resource
or have a peek in our vendor forum: http://www.diyaudio.com/forums/head-n-hifi-walter/
Old 23rd August 2012, 07:07 AM   #2749
@ Rullknufs
Sorry for that, I must have mixed up the cables when taking the pics, agdr is right, the cables must go in the other way around.
@ agdr
No registration required, but I took the guide offline to fix it.
Stefan
Old 23rd August 2012, 08:20 AM   #2750
Rullknufs's Avatar
Hopefully nothing is damaged, as agdr says. How important is it that the cables are twisted pairs per channel? I have some noise pickup at the momeny, but maybe it's because of that the wires are wrong?
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 06:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 03:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 04:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 03:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 16th April 2004 12:22 AM
Copyright 1999-2017 diyAudio
