Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 17th July 2012, 08:59 AM   #2651
digitfan is offline digitfan  United Kingdom
For my first O2 I got two 250mAh Tenergy batteries from ebay seller vt12340 in the US. They've been in use for 6 months now without problems.
The price for two delivered to the UK is currently 11.52 - I've no affiliation with the seller, but was satisfied with the service. No import duty/VAT to worry about for that value.
Old 17th July 2012, 10:44 AM   #2652
lorriman is offline lorriman  United Kingdom
Originally Posted by digitfan View Post
Built into a Black Cube clone case.
The O2 board was piggy-backed on the Black Cube clone pcb,
What is the black cube, and in what way is the O2 working with it? Or are they just sharing case space?
Old 17th July 2012, 12:20 PM   #2653
Sorry, shouldn't have assumed it was widely known.
This is the original
The one I had was an inexpensive Chinese clone. It produced enough heat to cook an egg, so I soon stopped using it.
My first O2 6 months ago was a revelation in terms of sound quality, but I wanted to have a more substantial case to go on my desk and a bit more connection flexibility (as NwAvGuy is planning with the ODA). When I noticed the O2 and the Black Cube (BC) pcbs had identical widths, I thought I'd try to make use of the case I already had.
The BC pcb uses a bigger Alps potentiometer and Neutrik 1/4" headphone sockets, so it was convenient to make use of the solder pads to mount the new ones I got for the O2 and have them line up with the holes in the front panel. After stripping all the components from the BC pcb I drilled holes for some mounting pillars for the O2 board and to route the wiring to the headphone sockets, potentiometer, LED, etc.
I was running my first O2 at 1x gain, so was able to completely leave out the gain switch and associated resistors.
The new Alps potentiometer has a really nice feel to it, and is logarithmic, so operates identically to the original O2 one in electrical terms.
Sound quality seems at least as good as my first O2, with the usual completely silent background. But it looks nicer to me (at least when the top is on the case).
Old 17th July 2012, 02:22 PM   #2654
The one I had was an inexpensive Chinese clone...etc
Great, thanks for that.
Old 17th July 2012, 03:30 PM   #2655
jtktam is offline jtktam  Canada
can you link the clone ?
-joe
our diyaudio forum - post your questions here
Audio Poutine - full web site coming soon
ODAC/O2 parts or assembled - Google spreadsheet
Old 17th July 2012, 04:12 PM   #2656
-joe
There's more than one, but mine was this one
I got it quite a while back, so I think some of the cosmetic aspects have changed.
Old 19th July 2012, 05:59 AM   #2657
brickj is offline brickj  United Kingdom
Thanks. I've given them a try too. You can't have too many PP3s!
Old 20th July 2012, 02:16 AM   #2658
fenderf4i is offline fenderf4i  Canada
I finished my desktop O2 tonight. Now I'm happy until the ODA arrives.
Old 20th July 2012, 05:05 PM   #2659
dewasiuk is offline dewasiuk  Canada
Originally Posted by agdr View Post
I wish someone would do that (SMD version)! The O2's physical size could probably shrink 30% or more if both sides of the board and SMD parts were used, and/or more stuff could be put on. You might want to shoot RocketScientist a PM or email on his website. Maybe he would have some interest in the project. Sounds like he is pretty slammed with the day job right now, but if someone else did a layout and board stuffing maybe he would be willing to look it over. By his licensing terms on the O2 design you could only use the (modified) design/board for yourself - the DIYers here couldn't do a group buy, etc from the way I read it. Maybe he would be willing to allow a SMD version of the PCB to be made available to the DIY community once the art is done and if he were able to find time to verify the results on his equipment.
You also might want to consider starting a separate "SMD O2" thread too, given the length of this one. I'll bet there are a lot of folks on the forum here with SMD experience that might want to chip in comments and ideas on something like that.
Just a thought!
I'd also be interested in combining the ODAC+O2 on one PCB, giving me some more experience in mixed signal design. I'm not sure when I could start playing around with this idea since I only have access to the Altium design software at work, and I'd prefer using that for the features as opposed to other freeware packages out there(unless there's comparable ones someone can recommend).
Old 21st July 2012, 06:10 AM   #2660
Francois G is offline Francois G  United States
Default Where is NWavGuy lately?
Originally Posted by dewasiuk View Post
I'd also be interested in combining the ODAC+O2 on one PCB, giving me some more experience in mixed signal design.....
Question for the designer; he mentioned PCB layout is critical to the DAC performance and especially noise.
BTW, What happened to our illustrious RocketScientist? His blog posts were reliably every month since way back, but he has not posted since May. Is he well?
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
