The Objective2 (O2) Headphone Amp DIY Project - Page 260 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 28th June 2012, 05:04 AM   #2591
Originally Posted by ramsfan6239 View Post
For a higher impedence headphone, like senn 650's, what would be a good gain for desktop only?
If in desktop mode it will only be playing from sources that are ~2V in output, then you will hit max power handling on the HD650 at a gain of 2.6x hence the use of 2.5x low gain by default. RocketScientist uses the HD650 as his go-to headphones.
Old 28th June 2012, 04:37 PM   #2592
olli1324's Avatar
Thought you guys would be interested to hear that 2 British magazines (Hi-Fi Choice and Hi-Fi World) awarded the EHP-O2 (well, O2) 5 starts and 5 'globes' respectively.
Good news indeed!
Old 28th June 2012, 05:57 PM   #2593
MrSlim is offline MrSlim  Canada
Originally Posted by fenderf4i View Post
Are there any differences in the B2 and B3 enclosure other than the height? Is the PCB the same hight from the bottom of the enclosure on both cases? I'm looking to order a custom front panel for a B3, and am wondering if I just increase the height of the template for the B2 enclosure in the FPE software if it will fit the input/output etc correctly?
There is a slight (~.9 mm higher iirc) difference in the height of the bottom of first slot from the base of the case.
Old 28th June 2012, 06:03 PM   #2594
Front Panel Express files are in my Blog
Old 28th June 2012, 11:29 PM   #2595
After some digging around, I've found the differences. See the following photo.
Old 29th June 2012, 01:41 AM   #2596
Click the 1 beside Bog Entries under my name for B3 panel files (and B2) from the group buy and I can confirm they work, since I built about 15 of the babydesktops with them
Old 29th June 2012, 04:09 AM   #2597
I got it and have edited it to my liking. Can't wait to get it together! I'm only going to have the volume and output jack on the front, keeping the LED on the back.
Thanks MrSlim
Old 1st July 2012, 11:47 AM   #2598
Ok, my amp works great but I got this problem:
LOUD TURN ON TRANSIENT: A few have reported this problem and its so far been Q1 and/or Q2 are damaged. Check the U2 pin 1 and pin 7 voltages outlined in steps 13 and 17 later in this section. And repeat the battery removal test in the DIY Testing section. Its likely Q1 and/or Q2 are either stuck on or no longer working in sync with each because one is damaged. Its also possible C16, C21 and/or C1 are missing, not soldered correctly, or the wrong value. Before replacing Q1 or Q2 see Circuit Board Construction regarding static precautions and be extra careful with the new parts.
13. U2 Pin 1 (Q1 gate pull down) Should be 11.8. If this is wrong but pins 2 and 3 above are correct U2 may be bad, the wrong part, or not installed correctly. Or theres a nearby solder problem.
-11,7
14. U2 Pin 4 (negative supply) Should be 11.8
-11,71
15. U2 Pin 5 (voltage reference) Should be 10 (same as pin 3)
-9,94
16. U2 Pin 6 (same as pin 1) Should be 11.8 (same as pin 1)
-11,7 (Pin1 -11,7)
17. U2 Pin 7 (Q2 gate pull down) Should be around 6 to 11.8 volts (9,8 on my board). If its much below 6 positive volts, or worse a negative voltage, but pins 5 and 6 are correct, most likely Q2 has been damaged and the gate is pulling pin 7 too far negative. The other possibility is R8 or U2 (see pin 1).
8,48
For me the above results looks good, i've checked over the components and they are all in the correct places, I've also done the Initial DIY Testing.
Any ideas to other test I could do to find the problem?
Old 1st July 2012, 06:28 PM   #2599
Check that C16, C21 and C1 are correct, and if so, reflow the solder on them? Did you work through nwavguy's troubleshooting section?
Old 2nd July 2012, 11:17 PM   #2600
VJK is offline VJK
Guys, I just built an O2 and when checking the resistances with U2 in its socket, I get around 235K instead of ~100K for R5 as mentioned in the testing section, any ideas ? Rest of all the other values checks out right except for R8 which instead of ~245K, it measures 235K. I raised the resistors and measured them and they both show their original values (270K). I ploughed through either ways and connected the transformer a 12V 1.6A (with the S1 off ) affair and found that the voltage between BT1+ and BT2- measures 12V which is nowhere near 23-24V as mentioned in the DOC... any ideas ? I rechecked the soldering and found no visible bridges or dry soldering. I am not new to soldering but a bit rusty on the debugging side, any help is appreciated.
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 06:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 03:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 04:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 03:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 16th April 2004 12:22 AM
Copyright 1999-2017 diyAudio
