Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 13th June 2012, 07:57 PM   #2531
Turbon is offline Turbon  Sweden
Turbon's Avatar
Originally Posted by swalter View Post
No need to beg ok, but seriously, have you tried a different USB cable, I had two faulty ones already... another thing to test would be if the hiss disappears with the 3.5mm connector, if both fails I send you a new one, but need the little hisser in return
Stefan
I don't get a sound with the 3.5mm soldered in place... Stefan, I'll send this one back to you - please send a replacement. There is nothing obviously wrong with it that hits the eye. It was probably manufactured on a Monday...
Brgds
Old 13th June 2012, 10:41 PM   #2532
agdr is offline agdr  United States
agdr's Avatar
Originally Posted by ethanolson View Post
K550
0.5V source (portable device) = 0.8x gain
2.1V source (redbook + 5% room) = 0.3x gain
Interesting! That fits in with something I'm doing. I'm essentially modding an O2 to be just a current buffer for the AKG K550s. I don't want to pollute Rocket Scientist's thread here with mods, so I've posted the reply in the mod thread here: O2 amp CRC, diode, cap, and heatsink mods
Old 14th June 2012, 01:45 AM   #2533
GeorgeBoudreau is offline GeorgeBoudreau  Canada
Hi Turbon,
Check to see the jumpers on the reverse side of the board are made. They are only need to be shorted when using the 3.5mm
George
Old 14th June 2012, 04:03 AM   #2534
Turbon's Avatar
Originally Posted by GeorgeBoudreau View Post
Hi Turbon,
George
yes, I will... Thanks George.
Old 14th June 2012, 01:43 PM   #2535
dixter is offline dixter  United States
Finished putting together two O2/ODAC setups yesterday.... I'm very pleased with the setup.
seems the ODAC adds quite abit to the O2... more body and more output...
I instlled Foobar2000 with the WASAPI component to bypass the windows stackup... all sounds fantastic...
also, thanks to who it was to suggest using the lan line wires for wiring the ODAC... worked great....
Old 14th June 2012, 02:58 PM   #2536
burgerking is offline burgerking
Hi, i found in my house an AC adaptor will it be suitable for O2 ?? Parametrs are: "15VAC~1100mA 16,5VA".
Old 14th June 2012, 05:56 PM   #2537
fenderf4i is offline fenderf4i  Canada
I'm about to begin assembling my O2. Are the only components that are susceptible to ESD the opamps and mosfets?
Old 15th June 2012, 02:08 AM   #2538
ethanolson is offline ethanolson  United States
If it fits when you plug it in, it'll work just fine. Those parameters are right in spec. It's got more amperage than you need, but it's really the voltage that matters most.
Old 15th June 2012, 04:24 AM   #2539
Turbon's Avatar
Same hiss trough the 3,5mm with another O2. I have a third O2 and my old Pioneer that I will test with tonight.
More about this later.
Old 15th June 2012, 12:37 PM   #2540
jtktam is offline jtktam  Canada
Turbon..
can you post some pictures?
-joe
our diyaudio forum - post your questions here
Audio Poutine - full web site coming soon
ODAC/O2 parts or assembled - Google spreadsheet
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
Copyright ©1999-2017 diyAudio
