Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 21st May 2012, 02:23 AM   #2471
coolhead is offline coolhead  Malaysia
Originally Posted by agdr View Post
Hey that is pretty slick! You found a way to use the (bigger than ceramic) film caps for the boost mod by sticking them on the bottom. I like the contrast there, the tiny SMD resistors and the huge 0.1uF film cap. That is what is needed electrically though. Looks like you are not going to use a switch on the boost mod (on all the time)? Another fellow has tried the boost mod and discovered the switch really doesn't fit anywhere in a B2-080 chasis. Have to go to B3. I just wired it all up to make sure it worked electrically, but hadn't tried to mount the switch in the box and got caught flat footed on that one.
Yup, it is on all the tim,. I need more bass all the time . and I also don't know where to mount the switch in my B2 case.
Old 21st May 2012, 09:48 AM   #2472
PATPP2 is offline PATPP2  France
Hi AGDR,many thanks for you reply,
By searching on the forum,i found a post of nwavguy who used 20V vgs mosfet with succes and one can add 15V zener in //to G/S
You understand i cannot order a 1,50 mosfet and pay 20 of shipping so i must find the part locally
In the meantime,i found the culprit it was not the mosfet but the comparator 2903!!,i replace it with an LM2903 and all works fine now for many hours
I'll post asap a photo of my box in... walnut
patrice
e
Vgs(max) of 20Vdc for the mosfets won't work (for very long, anyway). The power supply rails when running on AC are +/-12Vdc, so there is 24Vdc rail to rail, or more like 23Vdc after voltage drops across the schottky diodes and comparator chip output. The " 9v" NiMH batteries charge up to around 10.5Vdc, as I recall. That results in 21Vdc rail to rail when running on batteires, or right at 20Vdc after the various voltage drops.
So... you should get a mosfet with a Vgs(max) of at least 25Vdc. All the alternate mosfets RocketScientist lists in the BOM have Vgs(max) = 25Vdc.
Good luck!
Old 21st May 2012, 07:16 PM   #2473
agdr is offline agdr  United States
agdr's Avatar
Yep, a zener, or resistive divider, added on the gate circuit to reduce the voltage would also work.
That is good news you got it working!
Old 26th May 2012, 08:37 PM   #2474
T2T is offline T2T  United States
Originally Posted by jschristian44 View Post
Can anyone point me towards a Front Plate stencil so I can make my custom desktop version O2 amp? I want to have the RCA red/white plugs as well as the 1/4" adapter. Does the 1/4" adapter go on the front and the RCA plugs in the back? Also how do the RCA plugs attach as well as the 1/4" adapter. Thank you!
Be careful of JSChristian44. So far, he has taken members on Head-Fi.Org for $1,000+ in money and merchandise. Normally, he resides in Pennsylvania, but is apparently in Alaska for the summer.
Nothing beats the smell of solder vapors in the morning.
Old 26th May 2012, 10:02 PM   #2475
Zigis is offline Zigis  Latvia
Originally Posted by coolhead View Post
Here is the picture, the picture is not so good as I am using mobile phone to capture it. All old resistors are removed and new SMD resistors are mount underside of the board as it is easier to work with. Attachment 283268
Nice work, coolhead! Inspired by your work, I make bass boost too, few days ago. With ordinary resistors. Now in my O2 gain switch work as bass boost switch too. Since I use gain 2 and unity, Gain 2 is with bass boost and in unity gain position bass boost practically does not work.
I have 3K in feedback and 3K+100nf in parallel.
b.t.w., coolhead, since you use SMD resistors, you can make physically shortest possible feedback loop. Just solder feedback resistor direct between opamp's pin 1 and 2, and between 6 and 7. Leave in old place only bass boost RC.
Old 27th May 2012, 11:10 AM   #2476
patrice
e
and voila!
Old 28th May 2012, 11:54 AM   #2477
BuildMeSomething is offline BuildMeSomething  United Kingdom
Smile ODAC wiring...
Hi everyone, two quick reference pic's for those looking to wire their ODAC to the O2.
1. Odac lineout connects to P1 on the O2 board. P1.1 [square] = left, P1.2 = Gnd, P1.3 = right.
2. IIRC, with the input jack fitted you need to cut two traces on the reverse of the board.
Paul.
Listening with Gusto!
Old 29th May 2012, 05:28 AM   #2478
bada bing is offline bada bing  United States
If you wire to P1 holes, the ODAC will always be connected to the amp input.
If you want the jack switch to function to select between external source (jack in),
or internal ODAC (no jack in), you cut the traces and then ODAC L & R connection
are pins 3 & 4 of the input jack socket on the underside of the O2 PCB.
In order to route the wires for L & R, I squeezed some 24g teflon insulated wire through
the PCB lead holes at P1 and under the board to solder to pins 3 & 4.
Old 31st May 2012, 09:02 AM   #2479
Voodoo002 is offline Voodoo002  United Kingdom
Hi Guys,
Sorry to be a little of topic but I'm running a charity raffle to win JDS gear including the O2 Headphone Amplifier and ODAC to help build schools in Kenya and Tanzania, details can be found on the raffle page:
Charity Giving - JDS LABS CHARITY RAFFLE PAGE
There's an article on JDS Labs:
JDS Labs
We're hoping to generate a little more interest because we don't have many entries at the moment so your participation would be gladly appreciated, also the odds of winning are good
Old 1st June 2012, 11:27 PM   #2480
JZatopa is offline JZatopa  United States
Is there any reason I couldn't short C13 and C14 to remove all caps from the signal path? I know that I would have to be concerned with DC offset but is there any other reason I couldn't do this? Has anyone else tried this and noticed any difference in anything.
There is no higher religion than truth
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 06:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 03:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 04:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 03:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 16th April 2004 12:22 AM
