| Headphone Systems Everything to do with Headphones |
#2461 | |
My Blog |
#2462 | |
just make sure that your needle file is perpendicular to the hole, then you will get a nice even surface, otherwise your hole will get bigger and come out all crooked in the beginning work slow and get a feel for the technique.. i usually use a marker to mark off sections that is "high" (needs more filing) and then mark on the panel where to stop filing (edge of hole) -joe
our diyaudio forum - post your questions here Audio Poutine - full web site coming soon ODAC/O2 parts or assembled - Google spreadsheet |
#2463 | |
If Tandy in the UK is like Radio Shack in the US, they sell a "nibbler" tool meant to cleanly cut small squares of soft metal or plastic sheeting. To use the tool you just drill a small access hole for the tool and then you can create straight-edged cuts and openings easily.
My "nibbler" tool has saved the day on a number of DIY projects. Here's a link to what I'm talking about: GO! MOD Nibbler 29524 Metal Cutting Tool : General tools & tool kits | RadioShack.com Quote:
#2464 |
#2465 |
Can anyone point me towards a Front Plate stencil so I can make my custom desktop version O2 amp? I want to have the RCA red/white plugs as well as the 1/4" adapter. Does the 1/4" adapter go on the front and the RCA plugs in the back? Also how do the RCA plugs attach as well as the 1/4" adapter. Thank you!
#2466 | |
the rca would go to the back and be wired into the input header the headphone jack would go in the front and be wired to the output header you would probably want to relocate the volume control to the front as well. -joe
#2467 | |
So... you should get a mosfet with a Vgs(max) of at least 25Vdc. All the alternate mosfets RocketScientist lists in the BOM have Vgs(max) = 25Vdc. Good luck! Last edited by agdr; 18th May 2012 at 11:49 PM. |
#2468 |
Found some low ppm (<50ppm) 0603 surface mount resistors in drawer. Decided to replace R14, 20, 16, 22, 12, 13. Also add bass boast R16 and 22 with 0.1uF film cap as agdr suggested in the other post.
After done, hock it up to my BII DAC, I listen to it for 3hr. All i can say is, It is very nice to my ear, I like it a lot. Did know how to upload picture with iPad. Maybe later will upload. |
#2469 | |
#2470 |
Hey that is pretty slick!
You found a way to use the (bigger than ceramic) film caps for the boost mod by sticking them on the bottom. I like the contrast there, the tiny SMD resistors and the huge 0.1uF film cap. That is what is needed electrically though. Looks like you are not going to use a switch on the boost mod (on all the time)? Another fellow has tried the boost mod and discovered the switch really doesn't fit anywhere in a B2-080 chasis. Have to go to B3. I just wired it all up to make sure it worked electrically, but hadn't tried to mount the switch in the box and got caught flat footed on that one.
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
