The Objective2 (O2) Headphone Amp DIY Project - Page 239 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 21st April 2012, 07:46 AM   #2381
Anyone know what happened to Swalter's GB for O2 parts and the ODAC - it seems to have disappeared...
Old 21st April 2012, 07:56 AM   #2382
The moderators have moved every thread thats discussing the ODAC into one thread in the vendoors bazaar in the commercial sector
Old 21st April 2012, 08:16 AM   #2383
Found it - it's now here...http://www.diyaudio.com/forums/vendo...ustics-14.html
Bit confusing in that the title refers to one of the commercial vendors, but everyone who's selling ODACs is now merged in - and the links from NwAVGuy's last ODAC blog entry are all broken as a result...
Old 21st April 2012, 12:37 PM   #2384
@Turbon - perhaps the best place to discuss any mods to the ODAC would be on NwAvGuy's blog - me, I just want to get my hands on one! I think it's a shame that several vendors have had their threads combined, very confusing and not helpful.
Old 21st April 2012, 07:49 PM   #2385
Send a message via AIM to Yangoran Send a message via MSN to Yangoran Send a message via Skype™ to Yangoran
Here's just a little idea to make cables up front look tidier - if you use a little right angle adapter cable off of eBay, then you have a bit less sticking out front. I think I'll do the same for my 3.5mm input later on as well.
Old 22nd April 2012, 01:34 AM   #2386
swalter is offline swalter  Switzerland
life is beautiful...
Hi greenalien,
as you found out already all threads that discussed the ODAC in the slightest way have been merged together, even so I took the pre-orders explicitly out of the O2 thread.
I will create a new thread shortly in the commercial section, hope that one than stays...
Stefan
everything O2 and ODAC related can be found here: www.headnhifi.com - your DIY and audio resource
or have a peek in our vendor forum: http://www.diyaudio.com/forums/head-n-hifi-walter/
Old 23rd April 2012, 11:33 AM   #2387
I've finally drilled my frontplate. Write-up for those looking to cheapscate. General reaction/suggestions/ideas from what I wrote below most welcome.
To get the positions accurate I printed the fpd files at 106.95% scale (trial and error to get the scaling right). I also ticked "print reference points" in the print dialog which made getting the right place for the auto punch easy though it isn't a cross hair but a single dotted line. I used an occasional squirt of kerosene (uk: paraffin) for cooling and drilled slow. I have no prior drilling experience.
With advice from here, I used an auto center-punch and then HSS-G (for aluminium) drill bits. Despite the punch the drill did wander quite significantly. I had to punch a second time to try to steer the drill. Not a total disaster, as you can see from the pics, but I need to get a spot drill bit, I think, for the next two. The drill bits are Bosch 3mm, 6.5mm and 7mm, off ebay. I used a cheap, tapered hand-reamer (3mm to approx 12mm) off amazon to widen to the specified size and de-burr. I used too much force with the reamer on one hole and actually caused a heavy burr. The reaming generally didn't do a good job on the burrs but they aren't objectionable.
I used letraset transfers for the lettering. It was a nightmare. Quite apart from letters not taking or nearby letters also transferring, it was difficult to get alignment both in the vertical and the horizontal (letter spacing) and you can see the wonky results. I gave up once I had the absolute minimum done. I then laquered the letters, from my gold-leafing kit, to stop them coming off. The laquer was too visible so I ended up laquering the whole font plate. I should have stuck to just one coat as it looked alright. By the 3rd coat too much dust and dirt was making itself present and the surface was taking on an undesired texture. At least it's not shiney as varnish would have done.
My next attempt will be to use the print-'n-iron circuit-board creation technique. Print the lettering, using a standard laser, in mirror image and iron it on to the frontplate. I'll probably laquer that too but this time not fuss about the marginal difference in appearance of the anodised aluminium.
I used white-spirit to clean surfaces before letrasetting or applying the feet.
All in all it was a lot of fun and satisfying though the result is not as good as the GB face-plates. However at least I get to preserve the colouring for the blue and red enclosures.
From Farnell (minimum for free postage is 30) I got a silver volume knob (Farnell's pics are inaccurate; it's 12mm diameter 'slim', the one in my pics) and a fat 20mm silver knob (too close to the led on standard faceplate) for my B003 enclosure. It's held in place with a screw rather than the tight-fit semi-circle of the BOM knob. Very cheap. Much cheaper than digikey. I also got tiny rubber 'feet' to stop the O2 slipping off my table or scratching it.
Damnably I lost a screw for the enclosure. Anyone got a clue as to replacements? I've not much idea about such things.
Prep for drilling. The printed dimensions of the faceplate are actually slightly bigger than the real faceplate but the holes aligned exactly :
DSCF7602-w640 by midnighttoadstool, on Flickr
DSCF7612pp by midnighttoadstool, on Flickr
DSCF7616pp-w640 by midnighttoadstool, on Flickr
DSCF7614-w640 by midnighttoadstool, on Flickr
DSCF7618pp-w640 by midnighttoadstool, on Flickr
Old 23rd April 2012, 12:31 PM   #2388
jtktam is offline jtktam  Canada
I have tons of them since I don't use them for my builds. pm me your mailing address and I will drop a bag of them into the mail for you
I might have an extra set of front and back plates if you want to try again
-joe
Old 23rd April 2012, 02:11 PM   #2389
-joe
That would great, joe. I think I'll have to pay postage as we're on different continents.
Any Euro zone persons with spare screws and even better spare faceplates? Willing to pay postage, of course.
Old 23rd April 2012, 02:14 PM   #2390
I think this:
http://lifehacker.com/5903575/unleas...-and-amplifier
needs a bit of ODAC attention.
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
Copyright 1999-2017 diyAudio
