Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 7th March 2012, 10:07 PM   #2211
Cpl Clegg is offline Cpl Clegg  United States
Originally Posted by Amarphael View Post
I didn't check for continuity before taking out the pot but as i've said the signal is coming through, just barely audible.
I understand. I asked because I've seen high resistance shorts for input cause similar behaviors to what you've described. That is, low signal volume but normal level of crackle from volume pot travel. Just a possibility to consider.
Old 8th March 2012, 12:40 AM   #2212
Fsatsil is offline Fsatsil  United States
I just finished building my first o2 and I'm in the process of testing everything. The amp turns on and I get sound with no distortion or anything but I do get very loud turn on pop. I checked the troubleshooting info on the o2 website and it said to check the voltages of U2 which are fine, but I did notice u3 opamps positve voltage is low around 8.5v the negative rail is fine it's -11.65v. Also the voltage measured at r24(q1 gate) is reading 8.3v not -11.4. I'm reading through the trouble shooting guide but can't seem to figure out the problem. Any ideas? My ac adapter is 12v 200ma I tested it and it puts out about 14.2vac.
Old 8th March 2012, 01:41 AM   #2213
I think I've narrowed it down to a bad q1 not 100% sure just yet I'm gonna do some more testing and see what I find.
Old 8th March 2012, 02:52 AM   #2214
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
what could be the cause of the volume control not working? I'm hearing only the slightest level of signal with music on and the pot making rustle noises when turned.
opamp voltages all seem in order ( I'm running the amp on batteries currently and the numbers are apprixmately 70% of AC operation) and i've desoldered the pot and it meausres fine it seems- 9.71kohm in both channels...
any advice is very appreciated.
That pot should be silent when turning, noise indicates DC across the pot. Check for DC at the input to the pot. I don't have a schematic in front of me (I could swear I have one on this computer somewhere) but check the circuit ahead of the volume control for DC offset. Is there any DC offset on the output?
As for level: what you really want to do is supply a sine wave input signal (say 400Hz or thereabouts) and trace it with your meter on ACV from input to the volume pot, see where it disappears. You should be able to generate or download a signal like that from a variety of sources.
Old 8th March 2012, 02:52 PM   #2215
@nezbleu, I stand corrected. For some reason I thought this was considered okay for the O2. In fact, it's something RS specifically designed against. I'll have to be more careful in the future. Sorry for mixing messages, guys.
Old 8th March 2012, 10:29 PM   #2216
Zigis is offline Zigis  Latvia
Yesterday was not too lucky day.
Finally I received my O2 kit. Arranged parts and start to building amp. Slowly and with taste and enjoying
After few hours all solder jobs are ready, all come out perfect, nice lucking board.
I have not suitable transformer yet, so I insert 2 fully charged batterys and push power switch. LED start to shine, so far so good.
Then I take my multimeter to make some checks. I start with output DC, connect crocodile to output jack's ground pin and with probe touch one channel's output.
In this moment with loud bang exploded LED. Naturally. Half of red plastic are gone, inside electrodes are visible.
I am not sure, maybe I touch something with probe, maybe short output. However shorting headphone amp for a second is normal, putting phone jack in and out we do it every time. Maybe it is only coincidence, LED was defective or something else.
Any ideas?
Today I ordered new LEDs and to be sure FETs too from Farnell. Let's see tomorrow
Farnell have not original LEDs, so I ordered BOM's recomended replacement part Avago HLMP-1301
HLMP-1301 - AVAGO TECHNOLOGIES - LED, 3MM, HE-RED | Farnell Latvijas Republika
In O2 description he say, most important are LED's forward current and forward voltage, so I ordered this two LEDs too, just because of colour:
HLMP-1401 - AVAGO TECHNOLOGIES - LED, 3MM, YELLOW | Farnell Latvijas Republika
HLMP-K401 - AVAGO TECHNOLOGIES - LED, 3MM, ORANGE | Farnell Latvijas Republika
Anyone deeper in power part design, can I use this LEDs? Of course, proper working amp is more important then LED's colour. What happens if forward voltage is little bit higher or lower?
And any ideas what was happen with my amp?
Old 9th March 2012, 12:59 AM   #2217
agdr is offline agdr  United States
agdr's Avatar
Originally Posted by Zigis View Post
...connect crocodile to output jack's ground pin...
The two PC board traces feeding the LED run between the output jack ground pin and the edge of the PC board. If you hold the PC board upright facing the front, and then flip it over, that little round via hole to the left and slightly up toward the edge of the PC board from the output jack ground pin goes to the anode of the LED. When you connected your crocodile clip to the output jack ground pin it may have accidentally touched that metal via hole. That would put 9 volts right across the LED and probably cause it to pop.
If that is what happened the LED is probably the only casualty, but there is a small chance U2 would get nailed too. If that isn't what happened then make sure U2 is in the right way. The little dot on the top should be facing the batteries.
A better place to connect your meter for ground is the metal shell of the gain switch or one of the two holes of P2 closest to the PCB board edge. When checking DC output offset I use a 3.5mm stereo plug with the cover unscrewed (no wires attached) so I can easily clip onto the 3 connections.
Old 9th March 2012, 01:08 AM   #2218
I got back to testing my O2 today I double and triple checked all my voltages reflowed a few suspect solder joints and now it's working perfectly no turn on pop at all and it sounds great.
Old 9th March 2012, 06:02 PM   #2219
I think I may have spoke to soon I'm getting the turn on pop again and my power supply is unbalanced. It looks like the problem is the Q1 mosfet but id like to be sure before I spend any money ordering more parts. Any help would be greatly appreciated. Thanks
Old 9th March 2012, 11:53 PM   #2220
Sorr is offline Sorr  Australia
I have come across this project.
I only wont to use it with AC power.
Do I have to include the power management system or can I just power it from a standard +/- 15v supply?
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
