| Headphone Systems Everything to do with Headphones |
#2131 |
If anyone is interested, I have 10 complete O2 kits available for immediate shipment - UK only - see O2 Headphone Amp - Complete Kits (UK only)
#2132 | |
#2133 |
Sorry, but I've had to add an extra £2 to the EU shipping costs due to the cost of Airmail.
#2134 |
Any advice on configuring the O2 to match a set of Beyerdynamic dt770 600 ohm headphones?
#2135 |
Nothing in particular. You just need to keep the gain stage out of clipping by choosing your gain settings accordingly, as outlined before.
People with sensitive headphones/IEMs and loud sources tend to drop low gain to unity, but your Beyers are firmly on the other end of the sensitivity spectrum. |
#2136 |
Thanks, but I'm a hopeless newb to this. Would I be going for a higher gain setting e.g x6.5 or a lower gain setting e.g. x1 for my Bd dt700 600 ohm head phones? Or am I missing something and is it the output voltage I should be concerned about? I plan to use the amp at my office always connected to AC power.
#2137 | |
#2138 |
Hello,
eventually I will build the objective2, when PCB-boards are easily available in europe. It would be my first headphone amp then. I'd like to experiment on a perfboard first, having a little experience building a few guitar-stompboxes in the past. Just for proof-of-concept I'm thinking of building the amp-part of the schematic first and the power-supply and power-management later. Here my questions: Would it be possible to use temporarily two isolated 9V DC outputs of my guitar-effects power-supply for positve and negative rails of the o2 amp section? Or would it destroy something? (that the technical specs will suffer I'm aware). What would happen, if one of the both 9V-outputs is disconnected temporarily? Would my 300 Ohm headphone or the circuit be fried? Please be patient, because I'm writing not in my language, thank you. Last edited by unsopa; 26th February 2012 at 11:05 AM. |
#2139 | |
You will find out soon enough about the isolation. If they are not truely transformer-isolated you will get a nice spark when you hook the wires onto the center two battery terminal locations, that ties the "-" of one channel to the "+" of another. Won't hurt the O2 but the power supply may not be happy.
IPv6 world launch June 6, 2012: http://www.worldipv6launch.org/ Dual-stack IPv4 / IPv6 streaming: http://www.terena.org/webcam/ Google: http://ipv6.google.com/ Last edited by agdr; 26th February 2012 at 06:10 PM. |
#2140 |
Thanks, agdr,
but what I meant was to omit the O2 power management also and just to build the main amplification first and to get some first impressions. As far as I know the DCT 200 power-supply ist truely transformer-isolated and short-crcuit-protected. Under these circumstances - how big is the risk to damage the headphones by temporarily using just the 2 x 9V outputs on the rails of the amp-section? |
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
| Page generated in 0.13726 seconds (60.16% PHP - 39.84% MySQL) with 11 queries |
