Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 5th February 2012, 12:47 AM   #2041
tamu is offline tamu  Australia
I pulled the d6, d2, r1, r2 and also the q2. trying to find if any of them were the problem. well that didnt help much..
Ill do what you suggested now.
Old 5th February 2012, 12:56 AM   #2042
agdr is offline agdr  United States
agdr's Avatar
Yep, just follow those traces you can see on the bottom of the board going to pin 7. Either one of those 4 things hooking to it has to be shorted, or a short (solder bridge) directly to that trace.
Old 5th February 2012, 01:01 AM   #2043
I made a very noob mistake. r25 was 133ohms.
put the correct value in and now there is no more short. Ill solder everythg and see what happens.
thanks for the help agdr
Old 5th February 2012, 01:13 AM   #2044
agdr's Avatar
Yes but you've successfully troubleshooted it! Mistakes like that are easy to do and can be hard to find. You should have music shooting out of that O2 real soon.
Old 5th February 2012, 03:46 AM   #2045
MrSlim is offline MrSlim  Canada
Originally Posted by apassgear View Post
Hi guys,
been reading part of this big thread, but was wondering where to get the PCB and shematic.
Tony
O2 Details is the best place to start. He has the Schematic, board layout, etc.. Check the Vendor bazaar here for any Boards for sale (a few people are offering completed boards, but they may sell you one unpopulated).
Old 5th February 2012, 06:01 PM   #2046
apassgear is offline apassgear  Mexico
apassgear's Avatar
Thanks Slim
Old 5th February 2012, 10:38 PM   #2047
jfrana is offline jfrana  United States
Alright. I think I may be getting close.
Volume control is working properly (I ran a wire to the 20mm pot holes after damaging the board cups when trying to remove the pot -- it seems to work.)
After resoldering the leads near the U2 chip, I now have these measurements.
AC, on, no batteries for U2
1=-11.7
2=-8.8
3=-10
4=-11.7
5=-10
6=-11.7
7=8.5
Are these within proper ranges?
Measuring the resisters on top of the board (still connected), I have the measurements
R25= .39 on 20M
R5= .23 on 20M
R9= .02 on 20M
Old 6th February 2012, 12:08 AM   #2048
agdr's Avatar
Good job! Those voltage readings look a lot better. P2 of U2 is spot on now. You didn't list the positive rail voltage at P8, but that has to be OK (around +11.8Vdc) to produce that correct P2 reading. You must have your U2 back in the socket too since those output readings on P1 and P7 are doing their thing (almost) properly. The voltage on P7 is a little lower than what I would expect, but that could just be due to part tolerances.
What is the color code on your R25? The fellow I helped a few posts up had a wrong value in there. Maybe there are a couple of color codes that look pretty similar. If R25 is too low it could drag P7 down. Your R25 measurement is probably correct though. You are essentially getting R9 plus some power supply internal resistance, which is essentially in parallel across R25.
OK, so you've fixed up the U2 circuit and it is should be sending the proper control signals to the mosfets. So back to the original test you did in your first post in #1834 of running it on batteries with the chips in (headphones still unplugged though!), rather than AC, and then pulling out one battery and seeing if P4 and P8 of U4 go below one volt. P4 and P8 on U4 should be around the rail voltages (-11.8Vdc and +11.8Vdc) before pulling the battery out. If they do drop the mosfets have toggled properly and your power management circuit is working.
If that test works your O2 may be working. Run through RocketScientist's list of setup instructions again - especially the one about measuring the DC output voltage offset of each output channel and confirming it is around 3mV and not higher - and you may have a working O2. Give it a try after confirming those tests.
If one channel still won't work with the pot, try reheating both ends of R16 and R22, even if they look OK. Also make sure you have done that gain switch mod of bending the tab on the front left corner of the gain switch under, so as not to hit that via hole under it.
Old 6th February 2012, 10:59 AM   #2049
pjblakey is offline pjblakey  United States
Default O2/DAC combo
Thought I would share this.
An O2 and AK4393(with a couple of mods) crammed into a rather nice chinese aluminum enclosure. Need to straighten up the wiring.
Many thanks to RS for a very nice amp.
The input to the DAC is via an HA info spdif device.
This is my first effort at going PC based music system.
I'm very happy with the sound but would consider replacing the DAC with a decent USB input board. Anyone suggest one that would fit and sound as good?
Cheers
Peter
Old 6th February 2012, 11:04 AM   #2050
Cheers
Peter
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
Copyright ©1999-2017 diyAudio
