| Headphone Systems Everything to do with Headphones |
#11 |
Sometimes a square peg fits a round hole just fine
one thing, i havent looked up the part numbers for the opamps, because actually its not that easy to read them in the parts list linked to the google docs (pita to navigate too with no quick keys, even space bar doesnt work to create a hand to move the page when zoomed in) but just wondering, i assume the opamps you have used are limited in bandwidth? having a pretty cheap pot in the middle of the feedback loop for volume control doesnt cause any issues with stability?
#12 |
yeah i know all about the battery issues and comedic videos, just check out the RC forums, ive just started finishing up a lifep04 powered psu for a personal project with charge monitor for low voltage shutdown etc,(not so bad and actually pretty safe, but still subject to the save airfreight limitations as it hasnt been classified on its own, just comes under lithium chemistry)
lion is the worst (but its just so compact with high energy density its appealing), followed by lipoly, but its still manageable with the correct systems in place for protection. possibly still risky for diyers of varying levels though i guess |
#13 |
The volume pot is NOT in the feedback loop. Each stage uses local feedback.
There should be a "-" and "+" button on the left side of the Google Docs viewer. Click the "+" button to zoom in as much as you want. Unless you're using some really weird browser it should work fine. You can also just download the PDF and use whatever PDF viewer you want. The gain stage op amp has GBW of 27 Mhz. The output op amps have a GBW of 8 Mhz. They're almost eerily close to the ideal of "fast enough" without having excess bandwidth to create stability issues. In the first article I show the 10 Khz square response into capacitive loads--there's zero ringing or overshoot. None. I've tried to invoke instability and haven't even seen any hints.
http://nwavguy.com - Personal non-commercial audio blog |
#14 |
I can't seem to access the documentation package. Google reports "This service is not available"
#15 |
cool ok, fair enough, at a glance thats how it looked, maybe there is something up with either the pdf, or the viewer on google docs at my end because it wouldnt redraw when i zoomed in, just remained kinda half blurry and aliased, thus not being able to read part numbers or have any patience at all haha. i'll download it and have a look tomorrow. yeah was just asking, given your history i couldnt picture you publishing anything unstable for public scrutiny, but given the inability to read it i thought id ask.
ah IC, had a bit more success, i was reading it wrong, so the pot is wired as 2 shunt volumes in (well on the edge of each) the feedback, loop, but with no feedback currents flowing through the resistive element (only returns), haha nope right in the middle, just normal pots haha I withold further comment till i can download it, cant read ****. Last edited by qusp; 4th August 2011 at 07:09 PM. |
#16 | |
But, that said, I just checked and it works for me. Here's the link: https://docs.google.com/viewer?a=v&p...iOTc4&hl=en_US
http://nwavguy.com - Personal non-commercial audio blog Last edited by RocketScientist; 4th August 2011 at 07:17 PM. |
#17 |
yeah its being really buggy, could be safari or something, dunno, this is what it looks like here and it doesnt improve when i zoom
no excuse for not seeing the separate local loops though, guess i was just seeing what i expected to see, some global feedback. |
#18 |
When I use the Google Docs viewer it takes a second or two after you zoom in to download the hi-res version. Perhaps Australia is connected to the USA via dialup?
#19 | |
Looks good, but 1.9A diode charging current and that's with reduced load... would 1N5402 be more appropriate or am I missing something? Good work, BTW. Last edited by agdr; 4th August 2011 at 07:49 PM. |
#20 |
The 1N400x diodes are rated at 30 A of peak current for a half wave cycle (8.3 mS) and don't even get lukewarm in this application under worst case conditions. I don't think it's a problem unless I'm missing something? The diodes are running at 1.9/30 or 6% of their rated current.
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
| Page generated in 0.10830 seconds (73.42% PHP - 26.58% MySQL) with 11 queries |
