Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 9th January 2012, 02:45 PM   #1811
Turbon is offline Turbon  Sweden
Turbon's Avatar
So I saw some discussion earlier about a BOM change to fix a battery power-related sound issue. So I gave it a try and about 5 or 6 hours in, there was a very loud popping noise. Thankfully I didn't have my headphones on at the time, so I was checking all the electronics on my desk to find the culprit! At first I thought it was my iPod's hard drive dying. This click was really loud! I'm surprised it didn't destroy my RE-262s (IEMs).
Just confirming more than anything else... I hope that was the issue addressed with the BOM change
Kibble Fat.
It bettered things but as I wrote early in the thread it doesn't solve it for everyone. This weakness is built in to the realworld O2 and the model works for everyone in an ideal world. If you are afraid of your headphones it might be better to go back to the old BOM and use the oscillation as a low battery warning IF you think it worked better with your cans. But you didn't have anything connected at the time - right - so the rebound could have taken whatever time... So, do the rest of us wan't a constant drain even if nothing is using the batteries. I wouldn't.
Brgds
Old 9th January 2012, 05:01 PM   #1812
Kibble Fat is offline Kibble Fat  United States
So you think I have the latest configuration? I ordered parts a week before the boards shipped out.
Old 9th January 2012, 06:22 PM   #1813
Turbon's Avatar
In that case you probably have by the original BOM and could try RS new values since you by your post seem to be on the edge.
Brgds
Old 9th January 2012, 11:03 PM   #1814
sandbasser is offline sandbasser  United States
sandbasser's Avatar
I'm finally getting my Mouser order ready to go...can anyone tell me if the BOM dated 2 Dec 2011 is the most current??? Thanks,
- Ray
Old 9th January 2012, 11:10 PM   #1815
HiGHFLYiN9s is offline HiGHFLYiN9s  United States
HiGHFLYiN9s's Avatar
Just finished up my build. Unfortunately, both mini jacks are shorting out. Any recommendable substitutes that will fit (eg: Neutrik, Switchcraft)?
My DIY Electronics Blog: DIYAudioBlog.com
Old 9th January 2012, 11:15 PM   #1816
FREDtheDOG is offline FREDtheDOG  Australia
How are they shorting out ?
Old 9th January 2012, 11:15 PM   #1817
ethanolson is offline ethanolson  United States
Yes it is. Easy way to tell is if R9 is 33.2kΩ. If so, then you have the latest.
Old 9th January 2012, 11:28 PM   #1818
Channels are dropping on both the input and output and wiggling the plug temporarily solves the issue but it comes back.
It looks like the Switchcraft 35RAPC4BHN2 *may* fit, but I can't say for sure as the area behind the barrel is a little different.
http://www.switchcraft.com/Drawings/35rapc__hn2_cd.pdf
Old 9th January 2012, 11:32 PM   #1819
It seems strange that both jacks are giving trouble, have you tried another cable?
Old 9th January 2012, 11:35 PM   #1820
yes even with the larger ViaBlue connector it has problems.
EDIT: After futzing with it for another 20 min., the jacks are definitely bad. These were from Mouser, so I'm surprised no one else had an issue.
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
