Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 8th January 2012, 12:16 PM   #1801
lorriman is offline lorriman  United Kingdom
Originally Posted by ethanolson View Post
I put together a list of headphones that can make use of the O2's amplification and buffer capabilities. Compared to what a typical PMP can provide, the yellow indicates a headphone that needs more.
This is great.
What do you mean by 'buffer' capabilities? And what's a 'pmp'?
cross out this: Another list that would be fantastic is of headphone/source combos that would benefit from an O2's amplification.Should have read to the end. Couldn't find a 'strike'/'cross-out' option. Is there one?
Old 8th January 2012, 12:51 PM   #1802
regal is offline regal  United States
Originally Posted by lorriman View Post
This is great.
Buffer meaning current drive, in other words a PMP (personal music player aka ipod) may have enough voltage output but would distortion from lack of current drive into a given usuallly high load (ie low ohm phones.) The U3 NJM4556AD's are the fantastic buffers in the O2. They add no voltage gain but lower the output impedance (i.e. gsupply current/amperage buffer.)
Old 8th January 2012, 02:06 PM   #1803
raspunsen is offline raspunsen  Portugal
Just thought i could share the pics of my finished O2.
Not the most professional look of the front panel holes, but i don't really have the apropriate gear to make them better. For me, they are good enough.
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 8th January 2012, 05:22 PM   #1804
Seems like the forum is not friendly accepting imageshack links...
I can't edit my previous post, so i'll try again.
The holes were made with a dremel like tool, with a small drill and widening the holes slowly, checking the fit now and then. Not the best method, but the only one i could find.
Old 8th January 2012, 05:27 PM   #1805
Pano is offline Pano  United States
Pano's Avatar
rasunsen, please read this thread:
http://www.diyaudio.com/forums/every...tach-them.html
I will fix the photos in your post.
Old 8th January 2012, 05:56 PM   #1806
ethanolson is offline ethanolson  United States
Originally Posted by regal View Post
Yea, I can't imagine 1V thru Grado's even a breif transient, I hought .5Vrms was the edge of sanity with these drivers. I'm still scratching my head on the more power section of the blog. I brought up about how the AKG Sextettes need close to 200mW (almost twice the 115db number) yet the real world Grados are opposite (much less than the chart). I am glad RS published this 'cause its an important issue.
Possibly the ratings/specs for sensitivity are not such a good tool for estimating power needs because the manufacturers test methods are all over the map and more of a sales/marketing number than a meaningful (say NIST traceable ASTM) spec?
I definitely think that measurement data from the manufacturers needs to be accurized. I was looking at Sennheiser's website and found that one source listed 103dB/V and another 115dB/V. I suspected it may have been 115dB/V and 103dB/mW, but the numbers don't correlate when I run the math. So I just figured I'd leave it at 103dB/V and call it good.
Also, I have determined that AKG's numbers are off (as has Tyll Hertsens). My case was with the K171 being quieter at a certain power than the K272, though AKG claims a 3dB efficiency advantage by the K171. I found it was the other way around.
Sane listening levels for me are usually in the mid 70's which puts my headphones requiring about 10W. That's crazy. They still react differently with different amps, and I suspect it's the damping factor at play.
How would one specify headphones better? My AKGs are listed at 55 Ohm, but they measure 60-120 across the spectrum. Their efficiency isn't as good as specified, either.
Old 8th January 2012, 06:13 PM   #1807
Sorry for the inconvenience pano.
Next time i will not use imageshack.
Thanks for the help.
Old 9th January 2012, 10:41 AM   #1808
greenalien is offline greenalien
Default UK - NiMH Batteries at good price
If anyone is looking for decent NiMH batteries at a reasonable price, in the UK at least you can pop down to your local Lidl store, where they have 'Tronic' brand 9v 200mAH batteries for 2.99 each. This is one of their special offers, so they are likely to run out of stock fast, and it will be several months before they restock.
I have used these in my O2 and can attest to their suitability; I think they are the 8-cell type, as they definitely charge up to over 8.4 volts; the black finish also goes nicely with the black PCB!
Old 9th January 2012, 10:43 AM   #1809
Turbon is offline Turbon  Sweden
Turbon's Avatar
Now that was a bargain! Thanks greenalien!
Brgds
Old 9th January 2012, 01:56 PM   #1810
Kibble Fat is offline Kibble Fat  United States
So I saw some discussion earlier about a BOM change to fix a battery power-related sound issue. So I gave it a try and about 5 or 6 hours in, there was a very loud popping noise. Thankfully I didn't have my headphones on at the time, so I was checking all the electronics on my desk to find the culprit! At first I thought it was my iPod's hard drive dying. This click was really loud! I'm surprised it didn't destroy my RE-262s (IEMs).
Just confirming more than anything else... I hope that was the issue addressed with the BOM change
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
Copyright ©1999-2017 diyAudio
