| Headphone Systems Everything to do with Headphones |
#1581 | |
Awsome!! What type and size of reamers did you use? Were they tapered hand reamers?
#1582 |
matthaios - you did pretty well for the first time with a soldering iron!
The small 1/8 watters can be hard to spot a bad joint on, even with a magnifying glass. Reheating solder joints in a suspect area is always a good first step to try.
#1583 |
Yes, it is a hand reamer, tapering from 1/2 inch to about 1/16th of an inch over a distance of 4-5/8th inches. I bought it in the 1970's for 2 or 3 USD. I have no idea what one would cost today. See the photo in the original post.
#1584 | |
And I agree those who built an O2 as their first DIY project have a lot to be proud of. It's not a trivial build with nearly 80 components and a fairly cramped PC board layout.
http://nwavguy.com - Personal non-commercial audio blog |
#1585 |
I think the thing you need most when assembling O2 is attention. O2 is my first serious project (not the first time I hold solder iron, though), and I have to say it is awesomely designed and extremely easy to build (thanks again, RS!
) There are no SMD parts (my personal opinion - you have to be a neurosurgeon to solder those by hand), there are no closely located pads that would be easy to bridge... Consider this: the tip of my iron is 3.5 mm in diameter, and I have no skill, and I have assembled it right with the first try! I didn't have to re-solder a single part! If I can build it - everyone can build it. It is indeed much harder if you need optical devices to see clearly, though. Last edited by Alexium; 20th December 2011 at 05:06 PM. |
#1586 | |
#1587 |
After receiving the front panels from the GB (thanks @Flynhawaiian!), I finished my second build last night and everything passed with flying colors.
I thought I had a strange voltage issue at first, but then realized I had temporarily forgotten that the pin locations on DIP8 packages count in anti-clockwise fashion, not columnar. ![]() Thanks again, RS. You've really made it easy to enjoy both the build process and the end results. Now Santa just needs to bring me some new cans for Christmas so I can REALLY appreciate it. ![]() I can't even fathom the amount of time you've given to this project (the documentation alone is jaw-dropping), and just really want to say a heartfelt THANK YOU for everything. |
#1588 |
And a heartfelt thank you in return. Happy Holidays and Happy Listening! The more people look like the little guy under the batteries the more the time investment is worth it.
#1589 | |
#1590 |
billyk, my hand is just not steady enough for SMD, it shakes too much. I'd prefer to cut the leads, at least that's possible for me
I get your point, though. I think I'm a bit jealous to those who can actually solder SMD
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
