Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 18th December 2011, 02:51 PM   #1531
RocketScientist is offline RocketScientist  United States
RocketScientist's Avatar
@Alexium & Idjoel2000, I would suggest the resistor modification a few pages back to let the regulators run a bit cooler. The regulators are rated for 35 volts input and they should be comfortably under that even with the high transformer voltage and no resistors. I would go with the 15 ohm resistors--possibly even 18 ohm if you don't expect to every work the amp hard into a low impedance headphones.
The case temp of the regs should still be under 85C (even though the internal die temp might get that high under some conditions) and the caps far under 85C. So I wouldn't worry about the caps unless you plan to leave the amp on, and working hard, 24 hours a day 7 days a week.
It sounds like you have very sensitive headphones so that means the O2 will not be working hard at all. Removing the batteries also lets the regulators run cooler. 1X gain is easy, you can just clip, or heat and lift, one end of one pair of the gain resistors. Or if you have sockets, just pull them out. If you never plan to buy any voltage hungry headphones, and have a Redbook source, I would clip the 274 ohm resistors so you're left with 1X and 2.5X gain.
In terms of sound quality the O2 really shines with either headphones that require a low source impedance (such as balanced armature IEMs or certain full size headphones that need more resonance control) or with headphones that many sources simply cannot drive to suitable peak levels without current and/or voltage clipping or other heavy distortion. With typical dynamic sensitive headphones your old source might have been doing an good enough job.
@algfrimur, agdr is correct, the B2-080 case with metal panels should make your O2 fairly immune to cellular interference (RFI). I have to get my phone within a few inches (perhaps 10 cm) to hear some noises but it will depend on the phone, wiring, headphones, etc. If you still have problems, you could try making the 274 ohm input resistors 470 ohm or even 1K ohm and/or adding external clamp on ferrite suppressors to the input cable at the O2 end of the cable. As a last resort, in addition to those mods, a clamp on ferrite on the headphone cable near the plug should solve the problem.
But, overall, the O2 in its full metal case should be less prone to RF issues compared to many headphone amps--especially all the ones without an input filter or poor PCB layouts with excessive loop area.
http://nwavguy.com - Personal non-commercial audio blog
Old 18th December 2011, 03:36 PM   #1532
Alexium is offline Alexium  Ukraine
Not at all! With the gain of 2.5 I have more or less the same impression (sound pressure level-wise) of GMP 8.35D, old 30 bucks-worth Koss R/80 and $12 Koss KSC75. I believe this is usual sensitivity, maybe slightly above average, but not outstanding. I just don't need high SPL for in-doors use.
Thank you again for the advice, I'll perform the resistor mod. I'd like to add that the regulators are heating at idle, I didn't feel them getting any more hot when listening to the music, probably due to low power output needed.
P. S. It is so great you have designed PCB with switchable gain! I didn't really expect any audible improvement over XE510 (to my unskilled ear), because I have compared it to $200 (and well regarded) external soundcard EMU 0404, and found it's DAC+HPA indistinguishable from my XE510's DAC+HDA (and the owner of 0404, who has a more sharp ear, backed my impression up). The main for building O2 is to use it with DAC I'm planning to build, and the thing is that DAC will probably have output level as low as 0.5V, and having gain switch allows me to accomodate O2 for both my CDP and DAC. Even better, I plan to experiment with different DAC output stages, and I can build two different circuits and accomodate O2 for their different output level, which should allow me to switch between them faster so I can compare them more closely!
Old 18th December 2011, 03:53 PM   #1533
dewasiuk is offline dewasiuk  Canada
I'm finding that the suggested knobs are quite difficult to get on the pot shaft. I don't know if I'm just not pushing hard enough but I feel like the pot might dislodge from the vias if I push too hard.
Old 18th December 2011, 04:10 PM   #1534
Turbon is offline Turbon  Sweden
Turbon's Avatar
Maybe some heat softens them... I have the same problem.
Brgds
BTW: I can confirm that the new BOM with new values for R9 and R25 works for another brand of batteries as well - Fisher 270mAh NiMH Accu. This completes my testing of the former issue.
Old 18th December 2011, 04:22 PM   #1535
Yeah, the knobs can be a tight fit. Heating, and lightly "lubricating" the knob by tossing it in a glass of hot soapy water might help. Or, better still, slide the board out of the case (with the front panel) and put your thumb behind the body of the pot and with the finger of that same hand press the knob on. That takes the pressure off the pins and PCB.
@Alexium, the 0404 has a really poor headphone output but you may know that already. I have the 0404 and will be publishing some measurements of its DAC as part of my series coming up on USB pro audio interfaces.
If you mean you plan to try blind level matched switching that is a very good idea. You can make a 60 hz sine wave test track with Audacity (free) and use a cheap DMM to read the AC voltage playing back the track. That allows match levels accurately between different signal paths for fair A/B switching. If you let someone else do the switching so you don't know which is which you might be surprised when testing output stages
Old 18th December 2011, 05:05 PM   #1536
regal is offline regal  United States
Am I correct that there are no holes for stand-offs? Anyone found a good work around? Mainly am not good at drilling holes so precise to match pcb mounted compenents.
Old 18th December 2011, 05:10 PM   #1537
No, It never occured to us (me and 0404's owner). Perhaps, it's only poor with some tough phones?
Yep, I meant exactly that I'm a bit sceptical about my ability to tell the difference, though. Cheap Sony XE 510 is the top of sound quality inprovement I can hear, I'm afraid. I do, however, hear a difference between different headphones (I've heard a few in $100-$200 range), and I'm not quite happy with the current ones, so having a decent amp will be great when I'll find some better phones to test.
Old 18th December 2011, 05:11 PM   #1538
@regal, the board is designed to slip into a few different versions of the Box Enclosures cases. But there are also 3 mounting holes provided. The holes, and their precise coordinates, are shown in the O2 documentation PDF. They're also visible in several of the pictures. 3 holes are plenty to secure the board with stand-offs in any application.
@alexium, the 0404 (and every other pro interface I've tested so far including the O202, M-Audio, Tascam, Focusrite, A.R.T., Roland and Behringer) headphone output has a relatively high impedance. That causes all sorts of problems with many headphones. See: Headphone Amplifier Impedance
Benchmark Media also just published a new paper that provides additional objective evidence why higher output impedances are bad: Sonic Advantages Of Low Impedance Amps
Old 18th December 2011, 05:36 PM   #1539
[/URL]
Thanks I see those are standoff holes, don't know how I missed that. Thanks
Old 18th December 2011, 09:07 PM   #1540
ethanolson is offline ethanolson  United States
I just read that. It's informative. I was speculating about the part where they mentioned that the HD650's performed better (less distortion) than the MDR-V6's even when the damping factor was the same. I suspect that's because the Sennheisers are requiring more voltage, likely bringing the opamps voltage output into the sweetspot for lowest distortion (pushing the signal closer to the knee).
I've been wondering how to go about trying to get the O2 to feed my headphones at the ideal voltage for best performance of the opamps without making my ears go deaf. It's just for an excercise in achievement, really. Probably too off topic for this forum.
Good read. Thanks, RS.
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
