| Headphone Systems Everything to do with Headphones |
#1411 |
#1412 |
#1413 |
Some days ago I announced that I would write a step-by-step walkthrough for the construction of the O2. Problem is, I got sick and now I have some catching up to do with other things. Given the lukewarm response to my initial announcement, I am now in doubt if I should continue making the walkthrough or not. If there's sufficient interest in it, I will finish it in a while, if not, I will simply abandon my current effort and move on to other things. Just let me know.
#1414 | |
Paul
Listening with gusto... |
#1416 | |
I have now replaced both MOSFETs and all tests seem ok. I get ~250mV on the Low Voltage Shutdown test, but there is still very loud 'pop' when I turn it on. Last edited by Limp; 13th December 2011 at 09:38 AM. |
#1417 | |
#1418 | |
#1419 |
Thanks! Just curious about those. No ideas about the turn on pop though, unfortunately.
#1420 |
Anyone got any ideas on stenciling the markings on to a diy front panel? I'm currently thinking of using a common plastic stencil with a water based pen and then covering it with shellac or laquer. I did think of permanent marker but supposedly the alcohol in the shellac would make it smear. I'm also finding that permanent marker doesn't show up too well. I suspect water-based pen will be just as bad. Perhaps acrylic paint will be necessary.
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
