Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 12th December 2011, 03:21 PM   #1401
RocketScientist is offline RocketScientist  United States
RocketScientist's Avatar
@Limp, did you run all the power controller tests in the Initial DIY Testing section? You might have static zapped a MOSFET and one of them is stuck on which would cause one rail to turn on before the other making for a much bigger transient. With either rail low, both MOSFETs should shut off. Be sure and conduct the tests with no headphones connected.
http://nwavguy.com - Personal non-commercial audio blog
Old 12th December 2011, 03:57 PM   #1402
hbarradah is offline hbarradah  United States
Default Remote mounting pot
I'm planning on running this using the batteries for most of the time. Puting the battery on the board, the wires are pretty much right on top of the batteries, may be 1mm over it. Is that ok? or will the batteries introduce noise into the pot cables?
Old 12th December 2011, 04:18 PM   #1403
Limp is offline Limp  Norway
Limp's Avatar
I'm getting 24V across C8 and C9.
Bugger, I guess that means being careful with those MOSFETs just isn't careful enough.
Old 12th December 2011, 06:30 PM   #1404
Limp's Avatar
Everything seems fine, right up to the Low Voltage Shutdown test. With one battery intalled I get ~.5V, and with the other I get about half that. Now both are below the .7V you mention in the blog, but it is still a prety large discrepancy.
Is this where the problem is?
Old 12th December 2011, 07:10 PM   #1405
qusp is offline qusp  Australia
qusp's Avatar
unlikely, its DC, it doesnt introduce much EMI like transformers (AC) do.
Old 12th December 2011, 08:39 PM   #1406
Alexium is offline Alexium  Ukraine
FIY, "decoupling capacitors" are used on power supply lines to decouple power supply noise from other components and present a low power supply impedance to components.
Thank you very much for taking time to reply and educate me (I'm just starting to understand electronics).
I feel severe lack of electrical engineering vocabulary. In Russian C13 and C14 would be called "decoupling" or "separating" caps as they decouple signal from DC component, and C17/C18 would be just called "filtering" caps.
Is there any site or book which could help me to quickly learn most common English terms of electrical engineering domain?
P. S.
Limp, thanks for the refernce photo!
Old 12th December 2011, 09:27 PM   #1407
oslpag is offline oslpag  Sweden
Default Transformer
I am having a nightmare trying to find a power supplier for the O2 here in the UK. I have found this, would it work for the UK?
Old 12th December 2011, 09:35 PM   #1408
cool, thanks qusp.
Old 12th December 2011, 10:35 PM   #1409
agdr is offline agdr  United States
agdr's Avatar
It will if the plug fits properly in the O2. The output ratings are fine. 16VAC 700mA puts it right between the WAU16-400 and WAU16-1000 adapters on the BOM in terms of current capability, but the manufacturer doesn't specify if the output plug is a 2.1mm.
Sandan Limited (BS)
If you have access to the adaptor just try it to see if it fits, otherwise maybe the seller could confirm what output plug it has.
Old 12th December 2011, 10:39 PM   #1410
Sandan Limited (BS)
Thanks for the info. I am not too worried about the output plug, that can easily be sorted out. I will get one and see how it goes as it is not so expensive.
Thanks again
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
