Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 8th December 2011, 04:01 PM   #1321
RocketScientist is offline RocketScientist  United States
RocketScientist's Avatar
Originally Posted by abraxalito View Post
Yes - two opamps share the one resistor.
Now where did I put my "Duh!" cap.... For some reason I had it in my head the offset would be determined by whichever of the two op amps had the greater input offset current, but I believe you're correct. The currents sum between the pair. Thanks for that (and you accuse me of not listening ).
EDIT: Looking back through my articles, I could only find where I listed it as being a desirable requirement to have the worst case offset under 20mV, not where I claimed that was the actual worst case offset of the O2. If you're aware of some other reference to 20mV, please let me know.
http://nwavguy.com - Personal non-commercial audio blog
Old 8th December 2011, 04:53 PM   #1322
Jelle Schrijver is offline Jelle Schrijver  Netherlands
Jelle Schrijver's Avatar
Originally Posted by RocketScientist View Post
Some have suggested a digitally controlled analog volume control but the only decent chip I know of that won't totally destroy the DAC's performance is the flagship part from Cirrus which is really expensive and also would require a microcontroller.
For those that want a fancy volume control, how about this one: The Tentlabs volume (and input) control
Old 8th December 2011, 04:58 PM   #1323
@Jelle, that's my (and Doug Self's) preferred way of doing a high-end volume control--especially if you use through hole or really large high quality thin film SMT resistors. The only negatives are some don't like the relay racket when you change volume settings, 64 steps is not enough for some, and the 200 Euro cost far exceeds the price of the rest of the entire amplifier--even in assembled form.
EDIT: And, FWIW, I've read the eBay/Asian sourced DACT attenuators often use really small cheap SMT resistors (regardless of what they may claim as it's impossible to know by looking at the parts except they're usually tiny 0805 or even 0603 resistors) that have significant voltage coefficients--i.e. their resistance changes with voltage. Such non-linear resistors directly create distortion that can be far greater than the O2's inherent distortion. Doug Self has documented the distortion and it can be significant--especially at higher operating voltages and the pot in the O2 can have as much as 20 volts of swing on it. I'm fairly confident the Alps pot in the O2 will have lower distortion than the eBay DACTs.
Old 8th December 2011, 05:12 PM   #1324
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Just for reference - none of my remarks/observations anywhere on diya are intended as accusations. If you repeat the misinterpretation it'll just constitute further evidence of not listening
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 8th December 2011, 05:27 PM   #1325
Willakan is offline Willakan  United Kingdom
Ah, it's much nicer over here! Admittedly I'm biased - just cropped a 7 day ban at Head-Fi for suggesting (well, stating) Cheapskate had filled this thread with crap, was wrong about almost everything on every possible level and was incoherent in his argument. Perhaps slightly OTT in hindsight - oh well.
Back on topic and @NwAvGuy/RocketScientist, I was interested to read the ODAC announcement and in light of that must ask: what exactly do you think about jitter?
From what I've read, the suggestion was that it's a bit of a red herring, as jitter problems are generally apparent in standard measurements such measuring THD+N and thus measuring it in "isolation" (with J-tests and the like), whilst OK for product development, when you want to narrow down problems, is not really necessary when evaluating complete products. The main article I read on this was http://www.theaudiocritic.com/back_i...ritic_21_r.pdf , but I'm sure I don't need to point out to you the exact studies on jitter audibility that concluded you could get away with quite a lot of it. The general consensus from seemingly reliable sources appears to suggest that jitter is more of something for audiophiles to fuss over than anything approaching a real problem.
That said, seeing that you know considerably more about this than me, I was intrigued to find that your stance on jitter reads as vaguely conservative from an audiophile perspective, at least on your blog.
So what exactly do you think on the matter?
Old 8th December 2011, 05:40 PM   #1326
ethanolson is offline ethanolson  United States
If I had my way, I'd have a 128-step autoformer as the volume control but the feasibility of such is just not inline with the rest of this project in many ways: cost, size, existence the thing in the first place, etc.
Old 8th December 2011, 06:01 PM   #1327
@Willakan, I wrote an article on Jitter some time ago that shares many of my thoughts if you haven't read it already. But I should probably update it as I keep learning more about the topic--especially now that I've been involved in DAC development.
Perhaps most significant, I attended an AES presentation on jitter where music tracks were played with varying degrees of jitter. Even without the added sensitivity of a proper ABX test (the demonstrator was coordinating everything and there were gaps between each track) most in the audience could detect the jitter at moderately high levels. And when it was very high, my grandmother in the next room probably could have heard it. If I remember correctly, I think he was playing solo piano.
So there's no question, at some level, jitter is audible. The problem is correlating what's audible with say Julian Dunn's J-Test--arguably the most viable and accepted test for jitter available that works with most gear (the Miller Jitter Analyzer, for example, is based on similar principals). I can't make a definitive correlation with any certainty and I'm not aware of anyone else having done so either.
Given the lack of correlation, it seems prudent to minimize jitter when it's reasonable (and ideally inexpensive) to do so. Often that just means proper implementation of even fairly modest parts including paying attention to the PCB layout for cross contamination, digital signal degradation, ground currents, etc. Certainly some take it to arguably unnecessary extremes.
Perhaps ironically, in the DIY and "boutique" DAC arena many taking extra efforts (such as async, ASRC, excessive isolation, etc.) to reduce jitter rarely seem to properly test the end result to even know if they got it right. Jitter is a lot like other forms of distortion. It can have many sources and they're not all obvious or intuitive.
I also don't agree with the argument jitter shows up properly in simple THD measurements. Dunn's AES paper on the J-Test specifically talks about the requirement of toggling the least significant bit as part of the test. I can attest that one little difference makes a big difference on some DACs compared to just looking at a normal 11025 hz sine wave.
Jitter can be thought of much like road testing a new car. If you drive it on perfectly smooth brand new roads, you may conclude it rides very smooth, has a nearly ideal suspension system, etc. That's the normal sine wave test. But it's not until you take it on some beat up, pot holed road, that you can really appreciate how well the car deals with more adverse conditions--like the J-Test with the bit toggling.
If you feed a relatively low jitter source into a DAC you're likely going to get relatively good performance. But if you feed it a signal from a long cable, noisy source, or that otherwise has a high jitter potential, you start to notice much bigger differences between DACs. That's the idea behind the J-Test--it stresses the DAC more to evalutate its performance under more adverse conditions. It's a lot like test driving a car on a rough road.
So while I can't tell you a precise objective measure of when jitter is "low enough", I can still make an argument for trying to reduce it to reasonable levels--especially when that can be done for free or at a very modest cost. The sort of measures I'm talking about, unlike say improperly implemented async USB or ASRC, cannot cause any harm.
I also plan to be doing more blind DAC ABX testing in the future. And if audible differences are detected, it will be very interesting to compare all the measurements of both sources perceived as different.
Old 8th December 2011, 06:16 PM   #1328
T2T is offline T2T  United States
Plead the 5th. It's the easiest way out.
Nothing beats the smell of solder vapors in the morning.
Old 8th December 2011, 06:22 PM   #1329
MrSlim is offline MrSlim  Canada
Twisted Pear's Joshua Tree is a better deal.. Joshua Tree - A Twisted Log Attenuator
Old 8th December 2011, 06:36 PM   #1330
Thanks for the response. I have indeed read the article - I was struck by how it appeared less forthright and allowed for more uncertainty than your other articles, hence the question!
I would agree that THD+N is certainly not adequate by itself: the article I linked, from an engineer at Analog, just said that "Traditional THD+N versus frequency tests and FFT spectrum plots for input signals at various frequencies are enough to cover the effects caused by jitter." Obviously, this is from the perspective of a final evaluation rather than invalidating investigations of jitter during the design process. The general gist appeared to be that whilst jitter was certainly not irrelevant, the additional attention it receives over, say, opamp distortion doesn't seem objectively justified.
I wasn't of the opinion that jitter is inaudible, but where, very roughly (within an order of magnitude if needs be) you reckon the threshold of audibility lies? From what I've seen from Benjamin and Gannon, we're talking 10s of nanoseconds of jitter to be audible - whilst another paper found that only much higher amounts of jitter (hundreds of nanoseconds) was audible (EDIT: This one http://www.jstage.jst.go.jp/article/ast/26/1/50/_pdf although the methodology is in question to some extent - for example, they let the listeners use their own gear)
Can we agree that the sort of gibbering over hundreds of picoseconds of jitter in Stereophile is a total waste of time ?
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
