| Headphone Systems Everything to do with Headphones |
#1181 | |
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#1182 | |
#1183 |
@Willikan, thanks for sharing! That's the first one I've seen with RCAs on the front which cuts down on panel costs. I use that audio grade glue sometimes too. Good stuff!
http://nwavguy.com - Personal non-commercial audio blog |
#1184 |
@Alexium: It is really easier than you think.
You start with the resistors and Diodes. To find out what color codes on the resistors relate to what values, use an online tool. The diodes are easy, just go by the quantity used. Then the small caps (go by quantity, lead spacing and pictures... Mouser and Google are great). Then the DIP-8 sockets and everything else, they should all be self-explanatory when consulting the PCB and the BOM. Its really smooth sailing. I was surprised myself. Best regards, Jokener
New O2 Amplifier GB: Order Thread, Order Status PDF (Password: diyaudio.com) Pictures of the GB are in the Gallery: Click me! (User & Password: diyaudio.com) |
#1185 |
I change my thoughts, my words, my story? Why does this make one insane? Things change, new ideas, new facts, these things adjust perception, unlike you I'm trying to find the TRUTH, and not live according to DOGMA like some folks around here who get all kerfluffled when their dogma is challenged.
#1186 | |
Alexium:
@ Jokener: Construction might seem daunting, so people might get increased confidence from a step-by-step description, so that they actually see that it is not such a big deal before diving into the deep. Last edited by timpert; 5th December 2011 at 07:58 PM. |
#1187 |
CSA, et al., several years ago I used to get myself caught in "communication" traps and dug myself in deeper all the time trying to find stuff to back up my position. That tactic is best suited to talk radio. Now I just don't get emotionally invested in problems I'm trying to work out (including personal attacks) and things are much better because of it.
There's hope yet. Just give it time and realize the wisest among us are those who don't mind learning and taking correction even from the harshest of people. I'd love to make changes to the O2 as well, but I don't know if any would make it "better." Better for more cost and complexity isn't always better, is it?! I personally would much prefer to have it built to run on 4 AA eneloop 1500 batteries. The power circuit would really have to change and maybe not for the better.There's only one way to find out. |
#1188 |
Well this weekend I had a free moment and got my O2 working again!
I was completely wrong, the regulator was fine. I double checked the all solder joints and re-flowed any that looked suspect as well as all the components in the power section. While I was examining the board, flipping it around under a magnifying glass I felt some odd rattling from the 3.5 mm output jack that. It was faint, you felt it more then you can hear it. I de-soldered it (a complete pain-in-the-rear) and replaced it with one I had in my parts bin. Powered it up and it works again! At this point I'm going to sum it up as my stupid mistake, a weak solder joint that just happen to fail after a week of burn in. I should have triple checked re-flowed everything first before making outrageous presumptions. Thanks to RS and everyone that offered their suggestions. |
#1189 |
Mouser order is in, boards are ordered.
I'm pretty psyched to add this li'l guy to my collection. Thanks to RocketScientist for all the effort in bringing a new goodie to the community. I'll report in when it is assembled. Last edited by billyk; 5th December 2011 at 08:10 PM. |
#1190 |
The only vaguely difficult part of the build for me was avoiding/fixing solder bridges when soldering the MOSFETS and regulators, but that is more testament to my ****-poor technique and the fact I decided not to invest in any desoldering equipment. Hence I had to get rid of the bridges by heating the solder and poking them with a cocktail stick! Worked surprisingly well, all things considered.
EDIT:@billyk: Not easily, I'm afraid. The O2 uses a dual-rail supply. Last edited by Willakan; 5th December 2011 at 08:03 PM. |
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
