| Headphone Systems Everything to do with Headphones |
#1131 |
Amazon.com: Hot Air Rises and Heat Sinks: Everything You Know About Cooling Electronics Is Wrong (9780791800744): Tony Kordyban: Books
Personally, I'd just run a 12V transformer and avoid the issue altogether. Don't see the point of overvoltage on the regulator inputs . . . |
#1132 | |
#1133 |
@dewardh, that's why the WAU12-200 is the primary part number in the BOM. But, for those with low line voltage, or who want to do sine wave testing of the O2, the WAU16-400 does have some slight benefits. Because there's a lot of ripple from the half wave supply under load, if you heavily load the amp or have low line voltage, the regulators fall out of regulation on the "troughs" (low points) of the ripple. This is true even when a DMM still reads a high enough unregulated DC voltage.
The good news is the O2 has such high PSRR even when the regulators drop out of regulation under adverse conditions with a 12 VAC transformer, it barely changes the measured performance of the amp and hence is very likely inaudible. But it's still not ideal. The caps get warm just from the regulators. You can run a 79xx into thermal limiting and boil water with it and it will survive. Really.
http://nwavguy.com - Personal non-commercial audio blog |
#1134 |
Quick BOM question - I placed my mouser order based on the BOM effective 11/16. I got an update from mouser a day or two ago that one the parts is not expected to be available until early January. (Specifically, the 270-2.74M-RC 2.74Mohms 1% Xicon Metal Film Resistor)
I noticed you have a new BOM up as of 12/2. Should I go ahead and cancel my pending order and reorder per the new BOM? I poked around a little, but didn't find anything explaining the BOM update. Was this just based on part availability? Thanks! |
#1135 | |
#1136 | |
AC vs. DC there. Last edited by agdr; 4th December 2011 at 08:32 PM. |
#1137 |
@DubiousMike. You don't need to cancel the entire order but you can cancel just the 2.7M resistor if you want and have a source for any resistor in the 1.2M - 1.8M range--even a 1/4 watt (stand it on end). It's not part of the audio circuit so it's not a critical part. You can also leave R9 at 40K if you want. I explained the 11/30 posts here that same day in this thread. The 12/2 changes were also explained here on 12/2 and involved increasing C6 and C7 to 1.0 uF just as a precautionary measure. I don't have any evidence there's any benefit to that change. You can use the same cap as for C1 in the C6 and C7 locations by re-bending the leads or the part in the 12/2 BOM with the correct lead spacing.
#1138 | |
Not trying to be an *** but I put some numbers up that were basically inline with other numbers. So I found your response a tad smarmy. The reason I ask about the case temps is that if you aren't calculating the specific heat capacity for the volume of air in the case, along with the thermal conductivity of the case then you're just assuming what the temperature of the case will be. Last edited by cheapskateaudio; 5th December 2011 at 01:00 AM. |
#1139 |
I'll let others comment on that one.
#1140 |
Somewhere it has been previously written that the O2 is "a datasheet circuit with a Wikipedia output." So detractors have therefore chosen to focus on the relatively unconventional split supply to attack the design and designer.
CSA, it really does lean toward clueless. The reference is to the case of the regulator, the plastic part with leads and tab sticking out, not the B2 or whatever is used to enclose the amp. I think these detractors would like nothing better than to make the O2 a banned topic here or anywhere else.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine Last edited by sofaspud; 5th December 2011 at 01:34 AM. |
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
| Page generated in 2.51930 seconds (100.00% PHP - 0% MySQL) with 10 queries |
