Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 14th August 2011, 05:46 PM   #101
RocketScientist is offline RocketScientist  United States
RocketScientist's Avatar
Originally Posted by idjoel2000 View Post
yeah but personally, i always use the balanced output using xlr-rca converter and feed it to my single ended amp since the balanced out sounds better than the single ended one
A normal XLR to RCA adapter will only use half the balanced output and the voltage drops to 2.1 V RMS. If you tried to tie the two "hot" balanced outputs to the RCA to get 4.2V, half the balanced output from each channel would be shorted to ground inside the amplifier.
http://nwavguy.com - Personal non-commercial audio blog
Old 14th August 2011, 05:51 PM   #102
Arius is offline Arius  United States
Likewise, I was just trying to give some guidance to the folks here who are unable to grasp basic math or comprehend the O2's superbly detailed documentation.
Joel and USG: Why point out to others how many volts your source puts out?
Line outputs that follow CD Redbook standard puts out 2V typical. Diff outputs are 4.5V typ.
If you are genuinely interested in the O2 as a DIY project, then it's up to you to set the output level of your source correctly or in lieu of being able to do so, then set the input gain of the O2 correctly.
Again, you've pointed out how your source might overdrive the O2 in default 3X gain. None of you have bothered to ask how to change the gain to 1X or 2X, or after reading this forum and the O2 docs stated that you will, I can only assume you do not possess sufficient skills to DIY this project.
Old 14th August 2011, 06:08 PM   #103
idjoel2000 is offline idjoel2000  Indonesia
well, rocketscientist asked for input, i was just trying to give one..
personally i already quite understand and pretty much know what to do with my pcb when it shows up on my door
Old 14th August 2011, 06:36 PM   #104
SpaceTimeMorph is offline SpaceTimeMorph  United States
Originally Posted by Upstateguy View Post
I just looked up my Stello DA100 and it has a 2.4Vrms output signal level. I've never thought of the Stello as being a "hot" source but it seems to be very close to the maximum with a 2.5 gain.
My Pico portable dac is listed as having an output of 2.84Vrms on the HeadAmp web site (maybe I'm reading it wrong). Link I never thought of the Pico as being a particularly "hot" source either and have plugged it into all my amps, both portable and desktop, with no problems.
My feeling is that there might be a few more 2+V sources out there then we realize, but I'll leave it to the EEs here to sort it out.
The Stello DA100 only outputs 1.2 Vrms. The Stello DA100 Signature is listed as 2.4 Vrms but it doesn't specifiy whether or not this is balanced output... do you know which it is?
The pico is a DAC+HPA, the 2.84 Vrms quoted is max output from the amp section. Turning down the volume on the pico would allow for less voltage here.
Old 14th August 2011, 06:45 PM   #105
Etilletas is offline Etilletas  United States
Originally Posted by Rembrant View Post
The amp was made to be useful for sources that don't have a preamp out. Like portable devices and such. These guys are on about something because they can't blowtorch the input with 4vp from a preamp that they could either remove from the signal chain altogether, or simply attenuate. The loudness of this amp, at the right gain setting, would not require you to overdrive the input with any set of phones I can think of.
Why this happens.
The volume control pot was placed between the gain and buffer stages of the amp for various reasons. One of them being the opamp that was chosen for the gain stage. Ultimately, the attenuation could be moved to its own stage with buffers flanking but that would require at least two extra dual opamps and more board space etc. They could blowtorch that attenuation stage all they wish. There are always trade offs. This amps claim is superior performance at reduced cost. Not that one can't overload the input with a ridiculous amount of signal.
Thanks, that makes sense. So, say I wanted to use a higher gain setting for 600 ohm headphones - All I would have to do is reduce the volume of the source? i.e. set my Music Streamer II to like 50% instead of the usual 100%?
I think I could live with that.
Old 14th August 2011, 06:50 PM   #106
Limp is offline Limp  Norway
Limp's Avatar
That is the Pico DAC/Amp you're linking to. If this is what you are going to use as a source there is no problem, as it has a pot for you to attenuate those 2.84Vrms.
I have the Pico DAC myself, and plan to use it with the O2. If I read the WM8740 specs correctly, and these are applicable for estimating analog outputs, it should only be about 2Vrms, tops, so no problem.
(please, anyone, correct me if I'm talking non-sense here)
Old 14th August 2011, 06:52 PM   #107
Upstateguy is offline Upstateguy  United States
Upstateguy's Avatar
<snip>
<snip>
Correction: I think the2.84 figure is for the amp/dac
Old 14th August 2011, 07:00 PM   #108
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Someone should compile a database of sources with their 0dBFS output levels.
I'd do it, but I gotta... mow the lawn. Yeah, that's the ticket. I gotta mow the lawn. A really really big lawn. It'll take me weeks.
se
The Audio Guild
Old 14th August 2011, 07:27 PM   #109
Originally Posted by Etilletas View Post
Thanks, that makes sense. So, say I wanted to use a higher gain setting for 600 ohm headphones - All I would have to do is reduce the volume of the source? i.e. set my Music Streamer II to like 50% instead of the usual 100%? I think I could live with that.
I'll put some thought into making the article more clear. But it's best to work backwards from your headphones something like this:
Say you're going to use the Beyer DT880-600's which are the most voltage hungry cans I could come up with. They need about 5 V RMS to hit a seriously loud 110 dB SPL (the math is shown in the Gain Settings section).
Next you want to consider the source. The Music Streamer II specs list a "somewhat hot" 2.25 V RMS.
Then you figure out the gain: 5V Out / 2.25 V In = 2.2X to hit 110 dB SPL. So the default Low Gain setting of 2.5X will push the Beyer's past 110 dB at 0 dBFS.
You can also check for the maximum gain with the MS II if you want. For AC power that's 7/2.25 = 3.1X.
So if I was going to use the 600 ohm beyers with the MS II DAC, I'd aim for 2.5X - 3.0X and leave the DAC at full volume.
If you needed extra gain for something that was recorded/ripped way below normal levels, you could simply turn down the DAC volume, set the O2 to full volume, and use the 6.5X High Gain mode of the O2. Operated at max volume the output stage will clip before the input stage. Which means you get the full 7+ V RMS with no input clipping--plenty to ruin your hearing even with the voltage hungry 600 ohm Beyers.
To sum it up: Even using the default gains the O2 should work just fine with the 600 ohm Beyers and the HRT MS II DAC.
Old 14th August 2011, 07:47 PM   #110
Upstateguy's Avatar
LOL, my post was answering RS request for numbers just like joel's was.
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
