Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 2nd December 2011, 01:20 PM   #1061
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
hey hey thar agdr =) lol 0.2mm? wow. yeah mostly even fine smd stuff i use pretty large tips, faster to bridge the whole lot and clean after than worry about bridging pins one at a time =) i guess you gotta be pretty confident in your abilities to set out to bridge all of the pins together as quickly and completely as possible =) but flux and soldermask is your friend, surface tension is definitely one of my favourite natural forces. confidence is more than half the battle. for pth the 1 or 2mm and occasionally the standard conical hakko tip
i just noticed i typed the above wrong too. i meant to say
stuff that, get a second cheapie iron (not meter) and use both
but you answered the question anyway, so all good.
Old 2nd December 2011, 01:32 PM   #1062
dewardh is offline dewardh  United States
Originally Posted by cheapskateaudio View Post
in my experience with two amps the O2 can't drive HD650's and not eventually overheat the regs to the point they suffer reduced performance or even fail. Maybe I did build both my amps wrong
Yes . . . well . . . since the O2 does drive HD650's without overheating the regulators when built to spec and functioning properly, there is clearly something wrong. It takes a substantial current drain to overheat (or fail) the regulators, and that current must be going someplace (that it doesn't in the spec build). Others have suggested that you post pictures . . . that might help . . . at very least please post the voltages you measure at the regulator inputs, regulator outputs, and on the supply buss (after the power management circuit).
Also, if the regulators are getting hot (and their outputs are not shorted to ground) then something else must be getting hot also (the power has to be dissipated somewhere) . . . there are not a lot of candidate locations, so it should be easy to find. Check particularly the MOSFETs (which should not get even warm) and any electrolytic caps (which if installed backwards can draw a lot of current . . . since they're relatively big it often takes a while for them to heat up, so leave it "on" for a bit).
Old 2nd December 2011, 01:43 PM   #1063
Originally Posted by konga View Post
uncontrolled heat up of U6.
For the regulator to heat up it has to be passing current, so you should look for a failure on the load side . . . either a short to ground or some other component that is also getting hot.
Old 2nd December 2011, 01:44 PM   #1064
qusp's Avatar
yes, Myth: HD6XX are hard to drive
truth: given enough swing in the power rails (which there is easily) the HD6XX are a **** easy load, easier than IEMs
Old 2nd December 2011, 02:46 PM   #1065
konga is offline konga  United States
When my O2 was functioning it had no issues driving the HD650 either. I noticed no parts heating up beyond normal operation. It drove both the HD650 and the 32ohm A-T headphone I have surprising well. I am using the stock build from BOM on RocketScientist's blog.
I initially thought that both U6 and U5 were heating up but after a complete shutdown and full cooldown I found that it was just U6. U5 felt hot just from the proximity of the two regulators. One was heat soaking the other.
I'll check my board tonight or this weekend for any shorts or solder breaks then try the suggestions that RocketScientist posted earlier.
Old 2nd December 2011, 03:37 PM   #1066
RocketScientist's Avatar
Just to throw in one other piece of information here. There's no measurable change in the O2's performance from stone cold turn on compared to after it's been cranking hard into much more difficult loads than the 300 ohm HD650 (headphones I own and use with my O2 often) for hours. It takes the op amps a few seconds to settle down to their ideal internal bias points, and after that it makes no difference.
If the performance of 78xx and 78xx regulators significantly changed between 20C and 50C die temperature (well shy of their 125C max rating) I'm sure it would be well documented in the datasheets and elsewhere by now. They've been around forever, are made by at least a half dozen companies, and have been used by the millions. They're not even remotely some esoteric, or fussy, component.
If cheapskate's regulators are too hot to briefly touch driving HD650's (especially with no batteries installed), then either the AC wall transformer is putting out too much voltage, or as others have suggested, something else is drawing excessive current in the amp. It could be a wiring error, a wrong component, the amp could be oscillating at ultrasonic frequencies due to some error or mod, etc.
There have been several requests here and elsewhere for pictures of Cheapskate's amp detailed enough to show the components, op amps, etc. Such pictures would be very useful and helpful to trouble shoot this problem. As would the voltage measurements I have suggested.
http://nwavguy.com - Personal non-commercial audio blog
Old 2nd December 2011, 05:12 PM   #1067
OK, first of all, I want to stress this likely is NOT the problem being reported with near 0 volts on the negative rail and regulators failing. This also doesn't explain any 7812 problems. But it is a possibility that's worthy of further investigation if possible.
Agdr brought to my attention there are differences between datasheets for different brands of the 79xx regulator. I've reviewed 5 different datasheets and several of them are rather vague on the output capacitor requirements including On Semi. Fairchild has footnotes that don't seem to be referenced to anything, some suggest the capacitor is entirely optional, some "recommend" it, and one company (National) says it's "required". The rub is they suggest 1 uF not the 0.22 uF used in the O2. With the 7812 (positive regulator) the cap is genuinely optional for all brands.
I was trying to minimize the unique parts count for the O2 for a variety of reasons and that's why I used the same 0.22 uF film caps for C6 and C7 as used elsewhere in the amp. Under the assumption the caps are optional, that's a valid design choice. But I wasn't aware National requires a 1 uF cap. It's unlikely the 7912 is oscillating due to a 0.22 uF cap rather than a 1 uF cap but it's possible. For one thing, On Semi suggests caps are only needed with higher current requirements. And the the O2 typically runs well under 0.04 amps and it's a 1 amp regulator. That's only 4% of the regulator's current capability.
Well after I designed and tested the power supply, using NJR, Fairchild, and On Semi regulators, I added a 1 uF cap (C1) to improve the power on/off behavior. In hindsight, I should have specified that same cap for C6 and C7 just to be conservative. The original amp didn't have any 1 uF caps hence 0.22 uF made more sense.
National suggests a 1 uF tantalum or 25 uF electrolyic cap but I suspect that's related to the early days of the 79XX (it's a 2001 datasheet) before reasonably priced ceramic MLC caps even existed. So a 1 uF ceramic MLC should also work. If anyone knows differently, please let me know?
A REQUEST: For the two of you here who may be experiencing regulator problems, if you happen to have a spare 1 uF >= 16 volt ceramic cap (such as C1 used in the O2) or a 22 uF - 100 uF >= 16 volt electrolytic laying around, can you please carefully "tack solder" it across the outer two pins of U6 (the 7912) with short leads on the bottom side of your O2 board. Observe proper polarity if it's an electrolytic with the negative side on the regulator output pin. If your 7912 is genuinely dead, obviously it needs to be replaced first and any other problems corrected.
Because all my O2's, with three different brands of regulators, work perfectly I can't determine if the 0.22 uF cap could be a problem or not. If it's a problem it appears to be a very isolated problem as only 4 or so have reported any problems.
Old 2nd December 2011, 06:45 PM   #1068
dirkwright's Avatar
Hey! worked the first time! I'm done now! very happy! Thanks rocketscientist.
Old 2nd December 2011, 07:02 PM   #1069
H3nk is offline H3nk  Sweden
I just noticed that I've failed to get the solder to cover the contact area on the front side of the board on quite a few joints. Is this a problem? I suppose it's fine since the currents are quite low?
Old 2nd December 2011, 07:21 PM   #1070
@dirkwright, Great! You're welcome!
#H3nk, it's not a big deal as long as the bottom solder connections look good (shiny, good "flow", etc.). If you plan on removing and installing batteries often you might want to add solder to the top of the battery terminals as mentioned in Circuit Board Construction to add some mechanical strength to the terminals. Electrically they're fine without it.
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
Copyright ©1999-2013 diyAudio
