| Headphone Systems Everything to do with Headphones |
#1041 | |
#1042 |
@jokener; this iron has served me well; basetech ZD99. And it is more in the spirit of the O2, though less impresive.
#1043 | |
#1044 |
I think I'm in love..
http://www.amazon.com/gp/product/B00...n=&s=&v=glance |
#1045 |
is choosing a less facetious title...
I wouldnt waste youre money, ive had pretty crap experience with even their standard clone of the hacko hot tweezers. the ceramic element isnt user, or perhaps even factory serviceable and mine failed within the month. i found it difficult to even buy the whole tweezer set by itself,so i just threw it in the trash
#1046 | |
Bought myself two new toys last yearhttps://www.jameco.com/webapp/wcs/st...001_2099180_-1 https://www.jameco.com/webapp/wcs/st...001_2114685_-1 XYtronic-USA If I were doing it now I would get the one with that includes the tweezers https://www.jameco.com/webapp/wcs/st...001_2099219_-1 and/or the one with auto power reduction https://www.jameco.com/webapp/wcs/st...001_2099201_-1 I did all my O2s with the 0.4mm (1/64) connical tip. This rework station is pretty cool too ![]() Xytronics 988DTP Digital Soldering, Desoldering, and Complete Rework Station Last edited by agdr; 1st December 2011 at 11:57 PM. |
#1047 |
Meh, guess I can stick with my $30 ebay clone... although this looks useful:
http://www.amazon.com/gp/product/B00...A1UB0766FG4V9I |
#1048 | |
I agree with qusp, to a certain extent. Let's try to be diplomatic (I'm not very good at it though).
I see an entire page here that makes it look a lot like one needs a $200 DMM to make any diy progress. I completely disagree. A $5 analog meter is much better than no meter at all, and I'd implore newcomers to make at least that investment. Quote:
I'm up to date to last week or so on "that other thread" and it's beyond silly. And the main perp admits to not knowing mud from Shinola. As someone mentioned already, it's for entertainment purposes only. There isn't a big issue with the voltage regulator tabs touching the case of the O2. The 7812 tab is ground, and the 7912 tab is the input. Neither will cause reg chip failure, but the situation is unwanted. Those with "too high" voltage regulators, it seems to me at this point, didn't use the BOM part or didn't install it correctly. If the latter, it also seems easily remedied with a little resoldering. For those with O2 problems seeking help, don't be afraid. Long distance troubleshooting can be frustrating to both sides. Don't give up. Just remember that the accuracy of the information received will be directly proportional to the accuracy of the information given. PM me if you'd like; my bark is worse than my bite I assure you. There seems to be a rash of regulator failures, unlike anything I've ever been aware of. These are jellybean parts, so if it is "a bad batch" behind it all, it shouldn't be long before the official news gets out. Personally, I'm skeptical that bad chips are the cause. To RS I have only to say, no good deed goes unpunished. I decided not to kludge my (backordered) volume pot connections, so my O2 isn't operational yet. I've just been implementing some mods, setting others aside, and working on more. Hitting that power switch for the first time will already be more interesting than I ever imagined. And that's still without the cans plugged in!
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine Last edited by sofaspud; 2nd December 2011 at 03:35 AM. |
#1049 |
What benefit would I have to using such a small tip to build my O2? It seems too small to be as fast as the larger tip I'm rolling with right now (a fatty 3 or 4mm). Seriously, I'm not soldering 603 or 0402 resisters or caps onto mine. Anyway, I'm totally open minded because you are far more experienced than I and do something that I haven't.
#1050 | |
In the other direction though - unsoldering - the fine tip rocks for getting one lead of small resistors out. I can wedge the tip under the resistor lead right above a pad, give it a second to heat, then just lift the lead right out of the hole with the tip.
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
