The Objective2 (O2) Headphone Amp DIY Project - Page 102 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 1st December 2011, 08:20 AM   #1011
RocketScientist's Avatar
@qusp, this is getting OT, but the trick with transformers is the frequency range you want. They can work fairly well but only over a limited bandwidth. The audio transformers in the cheaper ground isolators have serious trouble below 100 hz and start to get weird above 10 khz. The $100 ones from Jensen are much better but still have their limits. RF transformers are useless at audio frequencies.
There are USB isolators but the ones that work with USB 2.0 cost more than some of the Picoscopes. Most only work as 12 Mbps not 480 Mbps. All the USB scopes I know of with isolated USB only run at 12 Mbps and have really slow screen updates--which is especially bad for say trying to follow a music signal to observe clipping, or whatever. There's more about scope trade offs, etc. in my (rather dated in terms of my blog) Testing Methods article.
http://nwavguy.com - Personal non-commercial audio blog
Old 1st December 2011, 08:43 AM   #1012
REGULATOR FAILURES - I've been told there's some grumbling on Head-Fi about regulator failures with the O2? Has anyone here had a problem? 78XX and 79XX regulators are normally about as fragile as anvils.
I get lots of O2 related emails and private messages every day and not a single one has mentioned regulator failures. So it's a bit odd the fuss is ONLY at Head-Fi where a significant gang has tried to do everything they can to make the O2 look bad to protect various interests there.
The regulators in the O2 are thermally protected. Even if someone manages to get them too hot, they should just temporarily shut down. The only obvious way to fry them would be to use more than a 20 VAC wall transformer and exceed their maximum input rating. Obviously that's hard to do accidentally. And the impedance of the wall transformer and 2000 uF of primary capacitance forms a natural RC filter against line transients.
The only other thing I can think of is if someone used the wrong diodes (like the Schottky parts) for D3 and/or D4 and they shorted and are pumping AC into the regulators. But I would think the caps would ooze goo all over if that were the case.
I'm blocked from head-fi, so if anyone here cares to perhaps direct those concerned to post here or contact me via the blog, that would be great. Something seems very odd.
Old 1st December 2011, 09:45 AM   #1013
@RocketScientist - you seem to have hit on the one downside of the project - you release a design for a whole bunch of people with varying skills to build, and when some of them end up with something that doesn't work, they blame you, the design, the components - anything but their own incompetence!
I don't think you could have made the build process any easier, this is the best-documented project that I can ever recall seeing, but some of the queries posted on this forum would suggest that not everyone has read your build instructions...
What happens if they have been mounted too high so that one or both of the metal tabs contact the case?
Old 1st December 2011, 10:42 AM   #1014
RocketScientist, the person who vocally reported faulty voltage regulators on head-fi has been directed here on numerous occasions by various contributers to that thread. TBH, the first diy O2 thread was locked and the second is now a bit of a joke (though quite entertaining to read).
It'd be quite surprising if the person who reported the faults posted here. His overall view of the O2 and yourself has been quite negative, to put it politely.
Paul
Old 1st December 2011, 10:51 AM   #1015
qusp is offline qusp  Australia
qusp's Avatar
I posted in there regarding the regs simply because there does seem to be a number of similar failures of the same part with the same symptoms, that to me deserves a closer look, thats all. i dont think anyone is questioning the thoroughness of the documentation and preparation for this project, I know i'm not and certainly any reasonable person wouldnt; but you just dont know until real numbers of people out in the real world build a kit and do remember thats what it is, not a design that will be built under consistent conditions
as mentioned there is a large number of people with different skills, different access to tools, different access to parts (some of which may even end up being sold fakes) and if there is a number of similar problems i would say although its probably not the designers fault, it is a fault. nothing that cant be recovered even if it does turn out to be linked to the design. with this many kits out there, i would be surprised if there wasnt a problem.
could it be linked to improper handling of the parts before they were packed?
also i think its unwise to use words like grumbling
Old 1st December 2011, 11:00 AM   #1016
Jokener is offline Jokener  Germany
I need to attend to building my own O2.
People that bought their kits from me have already finished theirs and here I am, with nothing to show...
I think I'll go out and buy a new soldering station first, though.
A Weller station from the 80s is good and well, but I think a shiny new Ersa i-Con 1 is in order...
(Or would you guys recommend strongly against it or strongly FOR something else?)
@qusp:
I just don't think that the "problem" would be this limited if it were caused by the design.
Of course the design has flaws. There is no such thing as a perfect design.
You can even argue about a simple piece of wire and if its perfect, so a design as complex as this... you get the drift.
But the "imperfections" are documented in the blog, the board layout and all the other information that is available.
But lets wait and see what that turns into.
New O2 Amplifier GB: Order Thread, Order Status PDF (Password: diyaudio.com)
Pictures of the GB are in the Gallery: Click me! (User & Password: diyaudio.com)
Old 1st December 2011, 11:19 AM   #1017
qusp's Avatar
exactly..
possibly unwise to claim victory after less than one month in service of the official kits/pcbs; my guess is RS designed this for much more than that.
and more specifically at you: to attempt to simply shift blame the builders by doing things like putting the word 'problem' in inverted commas, will not go well, especially since it was promoted by many as a design my cat could successfully finish because of the documentation and support.
give it a closer look first and that appears to be what RS is keen to do, which is all i'm saying. there areat least a couple others that have reported the same issue, hopefully one will come here so it can be gone over. good chance it really will turn out to be user error, but it shouldnt be assumed
Old 1st December 2011, 11:37 AM   #1018
Atilla is offline Atilla  Norway
Jokener I assembled this kit with an Ersa 'gun', where the only temperature control is the trigger, so I doubt you can have problems with anything
Anyway, I'd like to report that I haven't managed to blow this up yet, which is super-odd, given my track record so far.
I didn't even manage to short the S2 to the via, even though I forgot about the potential issue. It's been plug&play so far, absolute breeze to assemble and extremely enjoyable to listen to.
I went trough a pair of crappy earbuds, by clickng on high gain, volume to the max and leaving it there until they melted. Just to see how that'll go.
So far so good, now I'm running its batteries to depletion to test the shutdown. It takes me quite a while already.
Old 1st December 2011, 01:16 PM   #1019
jtktam is offline jtktam  Canada
I don't know how anybody can blow anything up doing this amp
it's like 1 on a scale of 1 to 5
if you are not careful and put stuff in the wrong place, or don't check for shorts or fitment issues, then don't blame the board
I built over 10 now and every one works 100%
no rectifier issues!
-joe
Old 1st December 2011, 01:43 PM   #1020
@Jokener - if you're going to use 60/40 solder then any decent small soldering iron will be fine - however, if you're going the lead-free route, a temperature-controlled iron is pretty much essential.
My recommendation would be to stick to 60/40, it melts at a much lower temperature, and thus is less likely to cause component damage during assembly.
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
Copyright 1999-2017 diyAudio
