Headphone Systems Everything to do with Headphones
little amp, newbie help?
Old 30th July 2011, 09:07 PM   #1
Dumle29 is offline Dumle29
Default little amp, newbie help?
okay, so im gonna go to this lan in october, however, my headset is pretty good at blocking out the sounds around me.
so i came up with this idea.
basicaly, its a box with a little mic, that splices the mic sound into the headphones
so here is what i thought:
mic--preamp--headphoneamp--out
lineout from pc/playstation 3--headphoneamp--out
so three inputs and two outputs, left in right in and mic in, then left out and right out, (with mic on both)
i need to be able to adjust both the lineout volume and the mic volume independently.
heres my problem... how the hell do i do that??
Old 31st July 2011, 02:00 AM   #2
gootee is offline gootee  United States
Opamp circuits. There's one called a Summing Amplifier, which you can use to combine the signals from the mic and the line, for each channel. Upstream from those, you could have a buffer amplifier for each input. Somewhere in there, you can have a pot for each input's volume.
Go to National Semiconductor | High-performance Analog and download Application Notes AN-20 and AN-31. They contain schematics of the building-block circuits that you can use.
Remember to add decoupling caps on all of the opamp power pins.
Tom
Old 31st July 2011, 09:07 PM   #3
i have no idea what you said, well, i have some.
i googled buffers, and found out there was two kinds, i would think that voltage buffers are the ones i would need.
so i could do something like this:
Old 31st July 2011, 10:30 PM   #4
That's pretty-much correct. And each of the summing amplifiers would have an output.
But maybe I misunderstood what you were trying to do. Do you just want to listen to the mic OR the source, but not both at the same time? If so, you don't need to sum anything. You can just use a switch, right?
What does it take to drive those cans of yours? Do you know their impedance?
Download these, anyway:
http://www.national.com/an/AN/AN-20.pdf
http://www.national.com/an/AN/AN-31.pdf
Old 1st August 2011, 09:21 AM   #5
well messured with a multimeter they are 36 ohms, but im not sure thats the correct way to messure it,
they are sony MDR-XB700 50 mm driver.
i do want to listen to both the mic and the lineout of the pc at the same time
thanks for the help btw, im not that good at audio
Old 2nd August 2011, 03:31 AM   #6
Try it in LTSpice. It's a free download from linear.com.
Old 2nd August 2011, 04:06 AM   #7
godfrey is offline godfrey  South Africa
Maybe you don't need to build anything. I don't know about PS3s but PCs normally gave a Mic input, so you could plug the microphone in there and let your sound-card do the mixing for you. The standard Windows "volume control" software has a mixer that lets you set the levels separately for various inputs etc.
Old 2nd August 2011, 05:06 AM   #8
digits is offline digits
digits's Avatar
The easiest way of setting up the mixer is to open that annoying windows messenger icon that sits onthe status bar by the clock... inside it you will find and audio wizard... yeah,I know, odd place, but it seems to work best.
Old 2nd August 2011, 09:50 AM   #9
well my problem is that i dont have a microphone that goes in via jack, so it doesnt go in to the realtek chip, therefor it cant mix it
Old 2nd August 2011, 09:55 AM   #10
btw, how would i go about finding the inductance in LTSpice?
little amp, newbie help?Hide this!Advertise here!
Rotel 855 PICS, dac & opamp question for newbie... psonic Digital Line Level 71 8th April 2010 11:59 PM
Easy (newbie) Watts & Speaker Question Lash Car Audio 10 8th May 2008 02:02 PM
Help a newbie - modify an old amp to use it's multichannel power amp capabilities marquis@mweb.co Everything Else 6 10th May 2003 05:49 PM
Newbie Amp & Enclosure Advice Needed Ron Subwoofers 33 6th February 2002 09:20 PM
