Headphone Systems Everything to do with Headphones
Repair help wanted for Realistic HP-100 Electrostatic Headphones
Old 15th June 2011, 02:37 PM   #1
HIPCHECK is offline HIPCHECK  United States
HIPCHECK's Avatar
Default Repair help wanted for Realistic HP-100 Electrostatic Headphones
Need help finding a part to replace a 3.3 ohm PTH variable resistor. Is this a MOV, PTC, Thermistor? I do not know what a current replacement part would be.
Thanks for the help!
Steve
See pic:
If a inch of duct tape will fix it, 3 feet should fix it for life!!!!
Old 15th June 2011, 02:44 PM   #2
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
The burnt part looks a lot like a high voltage capacitor. If you look carefully, you should be able to read its value.
Wachara C.
Old 15th June 2011, 02:54 PM   #3
HIPCHECK's Avatar
I have a schematic on the owners guide. It has no markings but is listed as a 3.3 ohm PTH has a resistor symbol with circle around it.
Old 15th June 2011, 03:10 PM   #4
firechief is offline firechief  United States
firechief's Avatar
My guess is Thermistor, they are rated in terms of resistance. There are some 3.3 ohm ones for sale at DigiKey but not in the same package. MOV's "metal oxide varisistors" are rated in terms of voltage and current. This page might help shed some light on the subject.
Thermistors - PTC | Digi-Key
Is there a way to scan and post the schematic?
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 15th June 2011, 04:49 PM   #5
agdr is offline agdr  United States
agdr's Avatar
It is a PTC (positive temperature coefficent) thermistor, from the schematic here
AudioKarma.org Home Audio Stereo Discussion Forums - View Single Post - Realistic HP-100 Eletrostat
which is post #13 in this thread
Realistic HP-100 Eletrostat - AudioKarma.org Home Audio Stereo Discussion Forums
The third part down on this list from Mouser might be a good choice, without knowing the specifics of what is coming out of your speaker terminals. The rating is (3.3R) 60V and 4A, which should cover a lot of amps
Mouser Electronics - Electronic Component Distributor thermistor
95 cents and in stock...
http://www.mouser.com/ProductDetail/...KDCK%252bk0%3d
Suggestion: if it were me, I would buy two and replace the one on the other channel too. Since this one went the other probably won't be far behind (age), plus they will match.
Good luck!
Old 15th June 2011, 08:11 PM   #6
HIPCHECK's Avatar
Thats awesome, the original schematic listed that part as a PTH I guess a older description for the PTC. That is what I was looking for, Thank you!
Steve
Old 25th November 2011, 04:43 PM   #7
billjames is offline billjames
The wires are very thin and break easily. It can be fixed.
here's a step by step tutorial
Repair help wanted for Realistic HP-100 Electrostatic HeadphonesHide this!Advertise here!
List of vintage electrostatic headphones? Racket Scientist Planars & Exotics 12 29th October 2012 09:15 PM
WTB: Koss Electrostatic Headphones. mudihan Swap Meet 2 8th March 2009 04:15 PM
Koss Electrostatic Headphones Maxxarcade Multi-Way 0 27th January 2008 10:15 PM
amplifier for electrostatic headphones silke.wein Solid State 3 6th November 2004 01:07 AM
Stax electrostatic headphones npdang Swap Meet 0 21st October 2004 07:33 AM
