Shure E2C-N Plug Replacement - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 14th June 2011, 08:49 PM   #1
Default Shure E2C-N Plug Replacement
Hello
For the last two years my beloved Shure E2C-N 3.5mm right angled plug has been faulty so I wrote to Shure to enquire about the cost of repair or replacement. The E2-C model has now been replaced by the SE215 which could be supplied at a cost of 64.96p inc VAT after the original E2C-N had been returned.
After a quick hunt in the parts bin I found two rather nice gold plated 3.5 stereo plugs but they seemed rather large with the aluminum cover on. Using a watchmakers lathe I turned the thread and front bezel down just enough for the heatshrink to sit neatly on the thread and flush to the bezel.
I have attached three photos with the
- Original Shure right angled plug on the left
- Modified plug in the centre
- Un-modified plug and cover on the right
Picture List
  1. The bezel and thread have been turned down
  2. The cable has been cut to length and the ends tinned
  3. The completed plug with the heatshrink on
Please note : The Shure cable is VERY high quality with very fine copper strands and synthetic filament weave which has to be separated before the ends could be tinned. My x4 eye glass was not strong enough so I used the microscope, this is the hardest part of the job.
I'm sure on a second attempt I can get the heatshrink MUCH neater.
Miles
chip burn-out when plug-in or plug-out DVD signal lines xujing79 Class D 3 3rd August 2010 05:07 AM
Shure M95HE and Shure M97HE stylus interchange ashok Analogue Source 0 28th October 2009 05:34 AM
tube rectifier plug in s-s replacement pforeman Tubes / Valves 5 2nd June 2009 11:50 PM
Replacement Stylus for Shure V15VxMR phibes Analogue Source 19 12th December 2007 11:38 AM
Shure V15 stylus replacement problem namui Analogue Source 0 15th September 2003 10:23 AM
Copyright 1999-2017 diyAudio
