Headphone Systems Everything to do with Headphones
All Discrete Class-A Headphone Amp
Old 6th June 2011, 12:19 PM   #31
geraldfryjr is offline geraldfryjr  United States
One thing I would like to piont out Is that even though these circuits employ opamps is that they are still operating in class a mode.
Because when the opamp is powerd with a high enough voltage it is drivng the fets entirely in its linear range and never hits the crossover point.
If it does it would be at extermly high peaks and at the risk of destruction of the fets.
Now my transistor driven design would be considered pure class a though.
jer
Old 6th June 2011, 12:39 PM   #32
I started designing these type of circuits around 1995 and the stacked version in 2003 but I did not actualy build one until 2007.
I have also used them in a BTL configuration and used a little pizeo driver as a load and I was amazed in how clean and loud it was just hanging off of the breadboard.
I thought the thing was going to shatter.
I first tried sine waves ofcourse and then used some music.
I was using a resistor load and they weren't a high enough wattage and burned up quite a few to the point that I didn't have enough parts to continue.
It wasn't until a couple of months ago I figured out how to employ a high ampreage CCS to replace the load resistor.
So,I have yet to build that vesion as it is one of the many projects that I have going all at once!
the cool thing was I tried every different type of fets that I had rangeing from IRFZXX, IRF510,IRF640,IRF740 and IRF840 and they all worked.
jer
Old 6th June 2011, 02:00 PM   #33
Conrad Hoffman is offline Conrad Hoffman  United States
Ha! Gottcha all beat in the old fart department. I just found my original drawing. It's basically the same as I posted, but with different gain. It's dated 1985, so that was 26 years ago!
Jer, thanks for those circuits- interesting thoughts for some projects I'm looking at right now.
I may be barking up the wrong tree, but at least I'm barking!
Old 6th June 2011, 02:39 PM   #34
Very good,Conrad, I too have my original files on a floppy disk!
Anybody remember those?he,he
Glad you enjoy them and I hope they can be of use to you as I have many more versions and different styles of configurations.
jer
All Discrete Class-A Headphone AmpHide this!Advertise here!
Discrete Single End TRUE Class A HeadPhone Amplifier lineup Headphone Systems 30 29th May 2009 10:44 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Discrete simple headphone amp kubeek Headphone Systems 15 7th September 2007 05:13 PM
Discrete Headphone Amp Q weinstro Headphone Systems 1 24th September 2003 10:48 PM
