Headphone Systems Everything to do with Headphones
Hiraga "Le Monstre" for headphones.
Old 31st May 2011, 06:51 AM   #1
owenhamburg is offline owenhamburg  Germany
Default Hiraga "Le Monstre" for headphones.
Dear all,
what do people think would be the best way to convert the Hiraga "Le Monstre" into a headphone amplifier, are their any reasons not to do this?
I imagine reducing the current is all that is needed, but will the amp break if current is too low?
I assume that all that is needed is to increase the 1 Ohm current monitoring resistors to say 2.2 Ohms and reducing the bias resistors from 1K to 500 Ohm.
This I assume would reduce the current by a factor of approximately 4 and so making maximum efficiency into a resistance 4 times greater than a conventional speaker amp, and similarly reduce the need for heat sinks by a factor of 8.
I have no formal training in electronics and was wondering if people would advice against this direction, and if so why?
Owen
Old 6th September 2011, 01:57 AM   #2
idlehands is offline idlehands  United Kingdom
Traditionally when speaker amps are used to drive headphones a high wattage power resistor was put between the output and headphone socket, the amp was not reworked. This maybe due to production cost rather than engineering best practise. I'm not sure how the ohm value is determined and it would change with the headphones. So you need to figure that out and what sort of PSU, some of those old class A PSUs have huge capacitor banks that are expensive.
Old 8th September 2011, 11:11 PM   #3
qusp is offline qusp  Australia
qusp's Avatar
the above was a lazy and kinda clueless way to do it, that companies did so they could say there was a headphone output without actually putting in the effort to design a circuit to do it properly.. that way results in less than optimal performance due to drastically increased output impedance which will compromise performance and alter frequency response. stick with your original idea. given the amp isnt built yet you would spend a lot more money on power supply and heatsinks only to limit the output. by burning it up in the output resistor. todays headphones are mostly much lower impedance and more efficient than then as well, this makes the problem worse.
Old 9th September 2011, 06:25 AM   #4
johnferrier is offline johnferrier  United States
johnferrier's Avatar
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 7th April 2013, 01:13 AM   #5
Telstar is offline Telstar  Italy
Which schematic corresponds from the"new" class a site?
BTW I hope the OP pursued his objective, I find the Monstre very well suited for headphone conversion.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 8th April 2013, 07:48 PM   #6
OK, i explored the idea, after reading various info.
This is my attempt (which I also posted in the le monstre thread), which won't be put on the bench before 2-3 months, so if anyone else is interested, they ought to wait
Old 11th April 2013, 07:04 PM   #7
pilli is offline pilli  France
Originally Posted by owenhamburg View Post
...convert the Hiraga "Le Monstre" into a headphone amplifier...
I have built the circuit that is described here as "bearing more than a passing resemblance to the Hiraga Class-A designs" (Circuit 2).
Don't know how similar it is to "Le Monstre", but it certainly sounds great...
It is also documented in this site (look for "headphone amplifier").
Hiraga "Le Monstre" for headphones.Hide this!Advertise here!
Hiraga "le monstre" Stefano Solid State 1434 13th August 2017 03:46 AM
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 13 30th May 2015 02:31 AM
hiraga Le monstre moochinazz Car Audio 4 18th April 2011 07:51 AM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 10:27 PM
Copyright ©1999-2017 diyAudio
