National LME49600 Reference Design Project - Page 19 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 18th March 2012, 06:42 PM   #181
JensH is offline JensH  Denmark
Is the LME49720 the optimum choice for the servo? I would have thought that a FET op-amp with a low offset would be better here. And then perhaps increase the value of R14 and R17 to attenuate noise from the op-amp?
With the LME49720 there could be 11mV offset from the offset current + the 1M resistors. With e.g. LF411 this could be reduced to 0.5mV from the offset voltage. The error from the offset current would be only 25uV (typical at 25 deg C) and 100uV max.
Of Course National would like to sell a lot of LME49720's, but it may not be the best choice for the servo.
Old 18th March 2012, 07:49 PM   #182
Avro Arrow's Avatar
My thought would be to use lme49990 for the gain stage
and opa132 for the servo...
Old 19th March 2012, 06:24 PM   #183
Nice layout, Neb! Do wonder about that transformer, it seems a bit small. Judging from va rating it should be ok but at max current it is perhaps a bit skimpy (not that you'll still have eardrums at max current :-) ).
Oemptempa petoempetapap
Old 28th March 2012, 05:03 PM   #184
qusp is offline qusp  Australia
qusp's Avatar
might I suggest you add an soic8 pattern inside and connected to the dip8 so people can choose to use soic8 directly instead of having to use an adapter? just about all modern high performance opamps are nolonger made in dip8, only SMD and high bandwidth/speed chips and their decoupling will perform better if connected to the PCB and opamp pins directly
Old 30th March 2012, 11:42 PM   #185
Originally Posted by RocketScientist View Post
http://www.national.com/pf/LM/LME49600.html#Overview
Just an engineering question, what are the advantages of placing a buffer in the feedback of the non-inverting configuration as shown in the schematic? I'm sure the answer lays in a lump of nodal calculations but asking an engineer saves me a little work
Old 31st March 2012, 11:30 AM   #186
Electrons are yellow and more is better!
peranders's Avatar
You add a buffer if the load is too heavy. A buffer will increase distortion performance and the possibility to have a heavier load.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 31st March 2012, 12:19 PM   #187
dirkwright's Avatar
Originally Posted by andrelim View Post
I am still learning about electronics, so please pardon any stupid questions i ask.
Is is possible to use the LME49600 in a headphone amp by itself?
My source has no problem driving my headphones to high volume, and it should be ok to have no gain.
Yes, I believe so. Most sources have plenty of voltage to drive the headphones to maximum, but not enough current. The LME49600 can provide the current.
Old 31st March 2012, 12:22 PM   #188
dirkwright's Avatar
Originally Posted by JustFJ View Post
Did anyone try to build this eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices ? their design used lme49710 + lme49600, or any comment?
Yes, I built that amp and wrote about it here:
My Head Phone Amp Project
Jim's Audio boards are good quality in my opinion, with complete gold plating and plated through holes. The schematic as provided has way too much gain, but that's an easy fix.
A servo is not required.
Old 31st March 2012, 12:51 PM   #189
dirkwright's Avatar
It would be fun to make discrete version of the this chip. It looks to me like a variation on the diamond buffer from Walt Jung.
Old 31st March 2012, 01:39 PM   #190
peranders's Avatar
I have made a version called SSB01
Parts on both sides and it's a 4-layer board.
http://www.diyaudio.com/forums/blogs...e-pcbs-me.html
National LME49810TB/LME49830TB UltraHighFidelity HighPower Amplifier Reference Design KLe Chip Amps 75 21st October 2013 12:47 PM
Help with Dayton Reference 2-way Project coldcut Multi-Way 10 23rd May 2010 01:07 PM
How about a 3 inch reference project? type Full Range 52 13th October 2007 04:17 AM
Copyright ©1999-2017 diyAudio
