Headphone Systems Everything to do with Headphones
What should i build?
Old 13th March 2011, 03:48 PM   #1
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Default What should i build?
I'm planning to buy some new headphones.
AKG K 272 HD
AKG K242 HD
AKG K240 MK II
AKG K601
Sennheiser HD595
These are the ones i've been looking at. I'm new at this area so please be patient
I have a budget of maximum $130 for the whole amplifier. I don't want it to be battery-driven since i'll use it many many hours every day.
And i want something that's relatively easy to build. I have never soldered anything before
Old 15th March 2011, 11:34 AM   #2
suntechnik is offline suntechnik  Russian Federation
Something based on IC like LT1210 maybe LME49600 with AD8610 in advance should be pretty easy to solder. The benefit of ICs once they are powered up in a right way (in accordance to datasheets) will deliver good sound without sophisticated tweaking using oscilloscope. Multimeter is a must to have anyway imho.
Power supply (good trafo) is the most expensive part or a project. ELFA.se could be a good place to order toroidal one. Use schottky diods for rectification from ONSemi for example. Quality capacitors are also important for audio applications. I would suggest using Nichicon Muse or Elna.
Old 15th March 2011, 03:15 PM   #3
Rullknufs's Avatar
Okay. I wont be able to know exactly what components i shall use. If you give me a list of the components i could do it though.
There's a swedish site called Electrokit which is much cheaper than Elfa. electrokit | elektronikbyggsatser | elektronikkomponenter | lysdioder | radio | LED | audio
It's all in swedish, but i think google translate might be able to do the trick. I don't know if they have suitable transformers or not.
I got a cheapish multimeter which i don't know how to use, but RTFM migh help
Old 15th March 2011, 05:53 PM   #4
Yes I know ELFA is on an expensive side but pretty popular here in Russia.
Regrading particular recommendation it might be better looking for a headphone amp kit instead that contains all necessary devices to assemble especially if you need reliable result at least expense while having limited experience.
Otherwise you may google schematics chose one you like and order parts on your own. It is much easier then seems at first imho. With IC like lt1210 it is possible place it on a heatsink and then solder all other parts to its legs. While it does not look pretty might be workable without making your own PCB.
I am saying in general because I do not want pushing particular technical solution. imho this is a nice kit to go with
24V Aikido line-stage/headphone amplifier kit
but would cost more then the budget mentioned above.
Old 15th March 2011, 06:34 PM   #5
Rullknufs's Avatar
Yes, that's a little more than i'm willing to spend.
Old 15th March 2011, 08:40 PM   #6
You can check this discussion as well
http://www.diyaudio.com/forums/headp...phone-amp.html
It has some nice pictures.
Old 16th March 2011, 09:38 AM   #7
backefel is offline backefel  Sweden
What do you think about this one?
Old 16th March 2011, 02:10 PM   #8
Rullknufs's Avatar
Not very much information about it :S
Old 16th March 2011, 03:34 PM   #9
mymindinside is offline mymindinside  India
Look on head-fi.org.
there is a lot of info on the mini3 and other headphone amps there. The forum is a good resource for anything headphone related. That is actually what sparked my interest in diy audio.
mymindinside
Old 16th March 2011, 03:54 PM   #10
Rullknufs's Avatar
Okay, writing a little shorter this time. I wrote a long text but then it was some server problems and i don't want to rewrite it all again.
The mini3 appears to have been designed to be portable. I want something that isn't. And i don't want to have anything to do with batteries, since i might use the amplifier up to 50-60 hours per week.
What should i build?Hide this!Advertise here!
what is the best to build? tadiam1 Solid State 3 21st May 2010 06:46 PM
First Build Phergus_25 Full Range 2 26th November 2006 03:56 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Looking to build a sub. jaybird Multi-Way 6 14th May 2003 12:52 AM
Copyright ©1999-2017 diyAudio
