Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 3rd March 2011, 08:05 PM   #1
apexaudio's Avatar
Default Mosfet Headphone Amp
Headphone Amplifier for 32 ohm or more with TO92 mosfets, 100uF can be shorted if there is no DC offset on output (drains).
Old 7th March 2011, 11:21 PM   #2
apexaudio's Avatar
DIP4 mosfets IRFD014 and IRFD9014 can be use intead BS170 and BS250
Old 21st March 2011, 03:19 PM   #3
Good looking Apex, you have any PCB designs for this Maybe, thanks for sharing I'm building a Preamp these days and this would work as the HP amp on it, I already built ur A Class PSU its Brilliant Ill post pictures on that thread
Old 22nd March 2011, 10:08 PM   #4
apexaudio's Avatar
I must design new pcb, old pcb is mono.
Old 25th July 2011, 03:43 PM   #5
Can i use another mosfets, like IRF510 and 9510? Or another power mosfet?
Old 25th July 2011, 03:53 PM   #6
jcx is offline jcx  United States
lots of devices can be used, including "power" mosfests, but you should try to keep the Q size somewhat porportional to the circuit requirements to avoid excess parasitic C
4 A rated Q for 100 mA is already a little overboard
Old 31st January 2012, 03:57 PM   #7
apexaudio's Avatar
BJTs also can be use instead MOSFETs
Old 31st January 2012, 08:54 PM   #8
Looking at the schematic, it uses the old trick of driving the buffer stage via the opamp supplies. Isn't that considered somewhat problematic when it comes to stability?
Old 14th February 2012, 05:09 AM   #9
routhun is offline routhun  United States
Not only the stability, I have a question about the distortion. The basic principle of this topology is the current drawn by opAmp is proportional to the input signal, and the resistors in series of the opAmp power supply generate proportional bias for the output devices which drives the load.
By my question is, how accurate is the power drawn by the opAmp proportional to the input signal? If it is not accurate, then output drive is not proportional to input signal means heavy distortion?
Thanks,
Routhun
routhun
Old 15th February 2012, 03:28 PM   #10
It all is within the feedback loop, so that shouldn't be too dramatic.
The opamp must be able to tolerate 1k2 of series resistance on the supplies though, which I guess means stability will depend heavily on the type used (ye olde TL07x isn't terribly critical AFAIK). A little too many ifs and buts for my taste, but YMMV.
Fault with MOSFET based headphone amp zebra100 Headphone Systems 8 7th October 2008 03:29 PM
Regulated PSU for MOSFET headphone amp zebra100 Headphone Systems 9 25th September 2008 05:59 PM
12 Volt MOSFET SE Class A Hi-Fi HeadPhone Amp lineup Headphone Systems 3 18th July 2008 01:49 AM
darlington/mosfet in emittor follower / headphone amp svokke Headphone Systems 11 8th June 2005 06:19 PM
Page generated in 0.07517 seconds (71.86% PHP - 28.14% MySQL) with 11 queries
