| Headphone Systems Everything to do with Headphones |
Guys,
What are your thoughts on these two buffers ? I see that HA5002 is used a lot in headphone amps. What about BUF634 ? It has a nice specs, at least on paper. Is HA5002 really much better sounding IC then BUF634 ? Let me know what you think. Thanks BUF634 is easity available from digikey.com HA5002 is harder to source. Thanks Sergey |
#2 |
#3 |
If you really want quality, just make a discrete push-pull class A buffer from Fets or bipolar devices. The only other alternative is tubes. Trust me. ;-)
#4 | |
I have the best experience with BUF634T, both parameters and sonic quality (you can visit my www to see an example of a circuit design). I am very sure that it is practically impossible to reach the same parameters by several discrete transistors, monolithic technology is superb for this purpose. The speed, thermal junction between components, repeatability ... And with BUF634 inside feedback loop you are able to reach THD of 0.0001% with OPA627, for example. You'll hear the result when listening to great philharmonic orchestra, violin, organ, trumpets ... |
#5 |
diyAudio Moderator Emeritus
Don't trust your website, the link on your www site to the audio-buffer is broken.
At the moment it is: file:///C:/Dokumenty/HIGHEND/MAC_hifi_publish/pokusny/buffer_en.html This one works: http://www.pha.inecnet.cz/macura/buffer_en.html I would take advice of John Curl serious. He has some experience with preamps to say the least.
It's only audio |
#6 | |
cheers peter |
#7 | |
Pavel |
#8 | |
yes, low thd is not the only sufficient parameter Pavel |
#9 | |
Have you compared the sonics of the dip BUF634 to BUF634T? Is there a substantial difference (assuming both are driving easy loads, far from max current)? cheers peter |
#10 | |
Pavel |
| AD8610, OPA134, OPA627, BUF634 SMD headphone amp | peranders | Headphone Systems | 72 | 29th June 2011 07:20 AM |
| Anyone interested in PCB's for OPA627/BUF634 based headphone amp? | Maxhawk | Headphone Systems | 24 | 17th December 2010 04:32 PM |
| Mini Portable Headphone Amplifier, with Discrete Diamond Buffers | cetoole | Headphone Systems | 3 | 30th May 2006 06:32 AM |
| YardBird OPA627/637 BUF634 preamp/headphone amp | Russ White | Headphone Systems | 4 | 23rd November 2005 01:53 AM |
| Page generated in 0.12921 seconds (81.42% PHP - 18.58% MySQL) with 11 queries |
