| Headphone Systems Everything to do with Headphones |
Just drew up a new schematic for a simple headphone amp with integrated li-ion power. Uses a max1555 to charge the li-ion and a ti boost converter to bring the voltage up to 12v (for -6/0/6v).
Does this design look sane to you? My main question are - Is +/-6v enough for decent performance? Do I need to do anything with the ground from the input (right now I'm just leaving it unconnected)? Any other thoughts/suggestions? I'm trying to keep it as simple and surface-mountable as possible. |
#2 |
is choosing a less facetious title...
yes your source needs a return path/reference or your input signal will be meaningless. you need to pick a signal star ground and connect it there. so either between c3/c4 or pick a more localized signal ground star point; perhaps between r5/r6. i dont have much design experience, but plenty of building and basic theory says your signal needs a reference
| Li-ion arrangement for CMoy-style headphone amp | hospadar | Power Supplies | 0 | 8th February 2011 03:15 PM |
| Li-Ion supply for ghettoblaster | hospadar | Power Supplies | 6 | 8th January 2011 07:36 AM |
| Help with charging Li-ion cell | EWorkshop1708 | Power Supplies | 14 | 29th May 2008 03:59 PM |
| T Amp, D Amp Li Ion 14.8V Battery 4.8AH 4800mah For sale | Xspunge | Swap Meet | 0 | 12th December 2006 01:39 PM |
| 3 pin li-ion batteries | Holger Barske | Parts | 1 | 12th May 2004 07:54 PM |
