Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 22nd November 2011, 05:44 AM   #901
forsakenrider is offline forsakenrider  Canada
DARN! how did I miss this? I hope there will be a second run of the SE-SE kit! I would love to build one.
Old 22nd November 2011, 07:29 AM   #902
qusp is offline qusp  Australia
qusp's Avatar
Owen, that is truly spectacular! Kudos to you and the guys at National, i dont think ive seen anything quite like that before. i find it intriguing that the THD is actually lower at 7v than 1V, is this simply due to less attenuation/higher DNR of the signal source?
the SE-SE amp with psu is a real bargain if looking for an SE amp. the phase plots are crazy
Old 22nd November 2011, 08:15 AM   #903
sek is offline sek  Germany
sek's Avatar
It's THD+N. The noise remains constant, thus contributing less to the figure with higher drive level.
Old 22nd November 2011, 08:34 AM   #904
qusp's Avatar
yeah i though about that after, thanks. given opc said he was bouncing against the AP signal generator noise floor i thought perhaps that was what was staying constant vs the signal amplitude; basically in the same way as you describe the self-noise THD+N.
its just not that common to see a loaded amplifier with signal input thats noise/distortion doesnt increase with amplitude, let alone the opposite
edit: except that there is no gain increase here, just signal amplitude
btw ive got a long reply to your massive post to me yesterday, but i might just PM you with it as its a 'bit' OT
Old 22nd November 2011, 10:51 AM   #905
igor0203 is offline igor0203  Slovenia
Owen, can you tell me height of populated PCB? Will it fit into 1U chassis?
Old 22nd November 2011, 12:14 PM   #906
qusp's Avatar
depends on the heatsinks you use for the PSU, if you use the chassis floor definitely yes
Old 22nd November 2011, 02:24 PM   #907
CaféNoir is offline CaféNoir  France
Hi owen,
I am upgrading my two PCBs-only to full kits, if that is still possible.
All in all:
-4 PSU full kits
-2 SE-SE full kits
-2 BAL-BAL full kits
Thanks!
Old 22nd November 2011, 03:17 PM   #908
nattawa is offline nattawa  Canada
Holy Smoke
The Wire . a piece of wire!
Old 22nd November 2011, 10:46 PM   #909
sek's Avatar
Owen,
any chance you could also pull off some RMAA measurements for comparison?
Thanks!
Old 23rd November 2011, 03:14 AM   #910
fualcr is offline fualcr  Canada
Post Order add on...
Hi Owen - your measurements just convinced me to do something I've always dreamed of! I would be most appreciative if you could please *add* the following to my existing order (if it isn't asking too much):
3 x BAL-SE full kits
1 x BAL-SE bare PCB
If you don't have the parts to fulfill the above as full kits, then please feel free to "downgrade" them to just bare PCBs. My diy studio IEM system is going to sound world class thanks to you!
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 04:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 07:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 04:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 10:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 09:47 AM
