Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 30th March 2014, 06:10 PM   #2051
BuildMeSomething is offline BuildMeSomething  United Kingdom
Some very nice looking builds from you guys Really need to finish off my BAL-BAL build, but am waiting on 'The Wire' DAC... hint, hint, nudge, nudge
Gain... as has been pointed out, even 1Vrms will drive a lot a headphones to very loud levels. Base gain on the SE-SE is 1.1, it's output should drive a set of HD600 very well
Listening with Gusto!
Old 31st March 2014, 04:49 PM   #2052
Fsatsil is offline Fsatsil  United States
Talema 62052 trans.
Would this be a suitable transformer if I'm planning to use 12v rails for my SE-SE build?
Old 1st April 2014, 12:30 PM   #2053
opc is offline opc  Canada
opc's Avatar
Originally Posted by Fsatsil View Post
Talema 62052 trans.
Link seems to be broken...
Old 1st April 2014, 12:57 PM   #2054
Invalid Request
Hopefully that one works. If not it's digikey.com part#1295-1064
Old 1st April 2014, 02:46 PM   #2055
I think I found the info I was looking for and it looks like that trasformer will be fine. If I want to run 12v rails I would just change r30,55 to 134K and leave r29,52 at 1.24M? Sorry for all the dumb questions I just want make sure I get my parts order correct. Nothing I hate more then being in the middle of a project and I realize I'm missing a single resistor and then I have to spend $5 shipping for a 10cent part
Old 1st April 2014, 05:32 PM   #2056
opc's Avatar
For -12V, the datasheet suggests 1.5M ohms and 162k, but what you have listed (from the BOM I assume) will work as well.
Also, the transformer you have listed should be perfect for 12V rails and powering an SE-SE.
Best of luck with the build!
Owen
Old 2nd April 2014, 06:24 PM   #2057
Owen
Thanks for your help. I did notice that the data sheet recommended different resistor values then the BOM which is why I figured it was best to ask. I think I'm going to stick with what's on the BOM just to keep things as simple as possible. I'm really looking forward to this build it will be interesting to see how it compares to my O2!
Old 12th April 2014, 10:34 AM   #2058
TNT is offline TNT  Sweden
I removed the big caps on output side of the PSU. I prefer it this way. For me this is a lot better withe the BAL-BAL. Bass absolutely still there just more precise and defined without any boom. There was something bothering me with the sound but now its relay clean and uncolored.
Old 12th April 2014, 05:45 PM   #2059
Thunau is offline Thunau  United States
Thunau's Avatar
how much more expensive would a run of boards with SM parts already populated be?
"Most people just say what they know, the wise ones know just what to say."
Old 12th April 2014, 10:00 PM   #2060
stachel is offline stachel  Germany
The PCBs (BAL-BAL) can still be ordered?
Regards Martin
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 47 12th April 2018 02:47 AM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
