Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 25th August 2013, 03:17 PM   #1871
Stixx is offline Stixx  Germany
Stixx's Avatar
Thanks Stixx for your answer, does standar gain enough to produce loudness for HE-500?
In my setup, yes... absolutely!
Old 25th August 2013, 03:20 PM   #1872
Stixx's Avatar
Across the normal 4 caps on there, I added 4 x 100uF 25V Black Gates F series (the cheaper ones as that's what I had spare) to my Wire BAL-BAL and they did their normal thing. Louder and 'bigger' and more transient bass, a bit coarse.
Good thing to do... unfortunately I don't have the space in my build.
My Audiosector DAC is quite plastered with BG though... doing their thing as you say .
Old 25th August 2013, 05:08 PM   #1873
qusp is offline qusp  Australia
qusp's Avatar
I believe opc uses a set of HE-500, so yeah it works
Old 26th August 2013, 11:23 AM   #1874
bobkojek is offline bobkojek  Indonesia
One more thing, how much voltage output at least from the source to get enough loudness then (if I use standard gain)?
So its time to wait for the boards
Old 26th August 2013, 02:34 PM   #1875
opc is offline opc  Canada
opc's Avatar
Indeed I do! Much like Stixx, I swap regularly between the AH-D2000 and the HE-500 depending on my mood and what I'm listening to. Also depending on my neck strength with the HE-500
I mostly use the AH-D2000 phones for everyday listening, or when I'm doing layout, watching movies etc...
I use the HE-500 for more critical listening as I find they have a slight advantage in overall detail and a somewhat more refined bottom end. They're terribly uncomfortable compared to the AH-D2000 though, so I rarely use them for anything other than critical listening.
As for drive level, I run the BAL-BAL at unity gain straight off the NTD1, which gives me 2VRMS output at 0dBFS.
I find this level satisfactory for everything I've ever listened to, but with quieter recordings I have found myself running it full out, which is ideally what you want. If you like ear bleeding levels, I might suggest running a gain of 2, but definitely try the default (unity) gain first if you have enough source drive.
Owen
Old 26th August 2013, 02:54 PM   #1876
Pardon me for such a newbie, so the default build is gain of 2 or it isn't?
Old 26th August 2013, 03:00 PM   #1877
hochopeper is offline hochopeper  Australia
Default is unity gain, voltage in = voltage out.
Old 26th August 2013, 03:45 PM   #1878
Which resistors do i need to change for gain 2 or more? is it the same for bal-bal and se-se parts?
Old 27th August 2013, 04:00 AM   #1879
I found jdkjake explanation for gain, is it for SE-SE only? What about BAL-BAL configuration?
Old 23rd September 2013, 06:56 PM   #1880
MWL168 is offline MWL168  United States
Has anyone tried using Twisted Pear Audio Buffalo/Legato IV with the BAL-BAL Wire?
The Legato has a common mode DC bias between the output and ground. I believe it’s about 6 VDC. I do not have electronic engineer background needed to analyze the circuits to know if the Wire can properly accept the balanced output from Legato (either with the ground connected or not connected).
Thoughts?
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 04:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 07:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 04:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 10:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 09:47 AM
Copyright ©1999-2017 diyAudio
