Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 3rd June 2013, 08:13 PM   #1841
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Yes, I know. Just been having problems wiring up my switch.
Old 3rd June 2013, 08:36 PM   #1842
JBdV is offline JBdV  Netherlands
maybe using it just as a single pole on/off switch for now by only wiring one mains wire through the switch can save fuses ....???
Old 3rd June 2013, 09:05 PM   #1843
opc is offline opc  Canada
opc's Avatar
Originally Posted by qusp View Post
what size were you using? you might have to look for another reason the fuses are popping ... the current draw on this amp is VERY small; 0.5A @ 120V is 60W, the amp draws less than 5W, and I doubt the inrush current is too huge. I would think 0.2A would be more than enough.
yeah... I'd second that.
After all the confusion with the switch, and the fact that indeed the circuit doesn't draw more than a few dozen mA from the mains means you have a serious problem if you're blowing fuses, even really low current ones. The only exception to this is if you're using a monster size toroid which may have enough magnetization current to blow a low current fuse. If that's the case, you'll have to size the fuse accordingly.
Also, not to be rude, but if you really can't get the stuff on the primary side sorted, you really need to get someone to help you. Messing things up there can get you badly hurt, or burn down your house, or injure someone else. Unless you know exactly what you're doing, you shouldn't be playing with any circuit operating at mains voltages. I'm being very serious about this... if I were you I would stop and get some assistance from someone who knows what they're doing.
Owen
Old 5th June 2013, 11:09 PM   #1844
Ok, no worries. I've wired it up correctly, as per Swalter diagram. Wired earth ground to the chassis too. Put in a 750ma fuse.
Sounds awesome btw.
Thanks for all your help.
I've put it in a large case... I might stick a small dac into it.
Old 5th June 2013, 11:52 PM   #1845
opc's Avatar
Excellent!
Glad to hear you're up and running.
Enjoy
Owen
Old 5th June 2013, 11:57 PM   #1846
qusp is offline qusp  Australia
qusp's Avatar
thats great! nice one, but you might want to look at getting a fuse in there that will blow before the power supply self destructs. fuses are meant to provide enough headroom for the load plus a little bit, not 20x the load current
Old 6th June 2013, 01:18 AM   #1847
what size are you suggesting?
Old 6th June 2013, 01:24 AM   #1848
qusp's Avatar
I cant suggest anything without knowing exactly what transformer and power supply you are running. with a transformer that is just big enough at say 8-10VA and the standard power supply. I already suggested 0.2A as being more than enough. a fuse is not a fuse if it doesnt trip in a fault condition until its too late.
Old 6th June 2013, 04:20 AM   #1849
opc's Avatar
A new run of these boards is now available!
Please see the following thread for details:
http://www.diyaudio.com/forums/solid...ml#post3516741
Owen
Old 26th June 2013, 08:51 AM   #1850
Mooly's Avatar
Posts deleted... lets keep it "topic and technical".
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
Copyright ©1999-2017 diyAudio
