Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 13th February 2013, 03:02 PM   #1791
IanAS is offline IanAS  England
Originally Posted by opc View Post
a "performance at any cost" approach.
Very glad to hear that Me too Although for me cost has become an issue of late.
Thanks for sharing your experience of those DACs I'll save some time and money and not buy and try the 9023 then I found that one on a PCB from Malaysia for about £40 delivered to the UK with the same USB receiver as the £100 ODAC. I wondered if it's better then the AK4396 DAC chip I'm using. The better ESS chips seem hard to obtain.
Ian
Old 17th February 2013, 05:01 PM   #1792
MWL168 is offline MWL168  United States
Thanks Owen!
Here are a few photos of the finished product as promised. Due to the lack of skill, patience and chassis space, the wiring is a bit messy and the metal work left much to be desired as well.
The WIRE may not be quite break-in yet, I only have maybe 30 some hours of playing time on it. But one thing I can confirm now, which I noticed within the first song I played through the WIRE, is that this amp does bass like no other headphone amp I've heard, it's deep and well controlled. The WIRE gives the HD650 bass extension that I did not know it possesses. The WIRE also appears to be extremely revealing - I hear nuances in the music that I did not notice previously.
Thanks again for your help! Without you, gusp and DIYAUDIO this amp would not have been possible!
Old 17th February 2013, 05:04 PM   #1793
I had difficulty attaching more than two photos so here are two more photos of the amp ...
Old 17th February 2013, 05:18 PM   #1794
MisterRogers is offline MisterRogers  United States
Can you say Audio?
Very nice! I've struggled with casework/wiring myself - though I strive to improve it each project I take on. Overall, given the space constraints you have - I think you've done a good job (from one rookie to another :-).
I've been working on my own casing for wire that rolls up my BIII, NTD1 IV and FIFO. I'm getting closer. I'm looking for 1/2 transformers that'll replace all these separates. Then, I'm putting together a UF.L/Otto II wiring harness that'll replace the current digital domain wiring. The NTD1 is known for throwing off serious heat, and this case design has finally put that issue to rest.
Old 17th February 2013, 07:18 PM   #1795
Co60 is offline Co60  United States
Finally got around to finishing this up. Thanks to Owen and everyone here for making this possible.
Housed in a re-purposed Lacie hard drive case. Plan on removing the Lacie logo, repainting and wiring an LED.
Old 17th February 2013, 09:32 PM   #1796
kuribo is offline kuribo
What is the output power of this amp into say, 8 ohms?
Old 17th February 2013, 10:05 PM   #1797
opc is offline opc  Canada
opc's Avatar
Kuribo,
I answered most of your questions here:
http://www.diyaudio.com/forums/headp...ml#post3367649
The current limit is 250mA peak for all the amplifiers and the voltage swing is 16V peak for the SE and about 28V peak for the BAL-BAL.
Owen
Old 17th February 2013, 11:22 PM   #1798
so about 7 watts for the bal bal version?
Yes, I would like to use it with electrostatics and an adapter (step up transformer) as mentioned.
I am told the adapter has a nominal impedance of 8 ohms and that the headphones need at least 4-5 watts power through it to work well....
Old 18th February 2013, 12:35 AM   #1799
Hi Co60:
Nice work and creative. It looks great!
Hi MisterRogers:
That's quite a project you got going there! Great work! Hope you find the transformer that meets your needs.
The chassis I use was bought from China - the shipping costs nearly as much as the chassis itself. All I had to do was drilling the holes for the Neutrik connectors and top plate ventilation.
I originally used Mogami shielded balance cable between the IVY and the WIRE but it was too bulky for the space I have to work with. I ended up replacing them with braided Cat 6 wires hoping the balanced topology of the set up would be more tolerant. We'll see if interference becomes a problem. So far it seems to be working fine.
Interestingly, the whole set up sounds different after I put it in the chassis. I don't think the wiring change or break-in explains it. Very curious!
Old 2nd March 2013, 12:40 AM   #1800
Yes...
It's in the works right now. I will be offering all variants in a new layout that is designed to fit in an extruded chassis.
I'll be offering bare PCBs, completely assembled PCBs, and likely a fully assembled product style version.
Stay tuned here for a link in the coming weeks.
Owen
Been several weeks-any updates???
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
Copyright ©1999-2017 diyAudio
