Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 8th January 2013, 09:11 PM   #1741
hochopeper is offline hochopeper  Australia
I would hope that anyone selling an enclosure would make it explicitly clear IF it is a momentary switch. I would be quietly confident in this case it isn't a mom.
There are plenty of circular push buttons with mains rated DPDT switch and an LED. They won't be high current switches but they will be plenty for a headphone amp.
Old 8th January 2013, 10:30 PM   #1742
tom3 is offline tom3  Greece
Has anyone pcbs for sale?(BAL-SE, PSU)
Old 9th January 2013, 05:06 PM   #1743
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I pulled out the power switch from my front panel.
It's a defond 6a 125vac - it has 3 tabs on it.
I should be able to wire it up directly to ac.
Old 9th January 2013, 11:27 PM   #1744
nattawa is offline nattawa  Canada
If it has 3 tabs only the illumination is almost certainly a neon bulb. Mains switches with a neon lamp almost always have an internal protection resistor and that would allow you to wire the third tab (for the lamp) directly to Neutral of the incoming ac without the need of extra components.
Old 10th January 2013, 02:07 AM   #1745
Ok. I'm using the middle and top tab. It seems to power up ok.
But since swapping out the jack, I seem to have a few touchy issues with the output.
I'll have to open it up to take another look at it.
Old 18th January 2013, 04:08 PM   #1746
Emphrygian is offline Emphrygian  Sweden
Owen (or anyone else who knows), what's the pitch for the input and output vias on the PSU board? By comparing to my 0.200'' pitch terminal blocks it looks like .150'', but I'd like to know for sure =)
Old 18th January 2013, 05:18 PM   #1747
opc is offline opc  Canada
opc's Avatar
Hi Emphrygian,
It probably is 150 but I'll confirm when I get home this evening.
Owen
Old 21st January 2013, 08:24 PM   #1748
Should I be grounding it to earth ground or can I leave the circuit floating?
Old 22nd January 2013, 01:03 PM   #1749
opc's Avatar
Hi Emphrygian,
Sorry for the delay... I just checked the layout and both inputs and outputs on the PSU are spaced at 0.125".
They were intended to have wires soldered directly to the pads, so I'm not sure if they make connectors with that pitch. Next time I'll opt for a more standard spacing if there is room.
Owen
Old 22nd January 2013, 03:14 PM   #1750
Stixx is offline Stixx  Germany
Stixx's Avatar
...Next time I'll opt for a...
hint, hint?
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 47 12th April 2018 02:47 AM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
