Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 22nd November 2012, 05:49 PM   #1691
IanAS is offline IanAS  England
Why not just fit the same components Owen used onto some Vero board, or better, Tripad board? It's easy enough to do.
Here are some I made for another project. They had to be 6.9 volts:
Old 22nd November 2012, 05:53 PM   #1692
grubyhalo is offline grubyhalo  India
Originally Posted by IanAS View Post
Why not just fit the same components Owen onto some Vero board, or better, Tripad board? It's easy enough to do.
I was considering that as my last resort as I am not an experienced DIY'er. Maybe I will look into it more seriously. Thank you.
Old 22nd November 2012, 06:13 PM   #1693
The heatsinking was done by the case the regulator fitted into.
If there was a next time I'd look at using more surface more components. With this project, on the non variable +5V regulators, I used just one surface mount, a tant cap which can be just about seen on the 3 regulators on the bottom right.
Old 22nd November 2012, 06:24 PM   #1694
That looks fantastic!
Old 22nd November 2012, 06:26 PM   #1695
I'm about to solder into the signal leads some Panasonic micro relays to see if I can hear any difference with the HD800's
I could; more dull treble, less distinct and more 'rough', especially on some metal chimes and any sound with fast edges.
I was able to hear the difference when I unplugged the XLR to varnished solid silver to XLR lead as well. Was more expressive and cleaner, better pronounced 'highlights'. Seemed as if the treble had been turned up a bit.
Not vast changes, but ones worth having.
Old 28th November 2012, 08:53 PM   #1696
BuildMeSomething is offline BuildMeSomething  United Kingdom
Finally gotten around to rectifying my [hopfully] final mistake from when I built my original The Wire se-se. I used a 10K Alps pot but didn't change the related resistors. I did remove the 1K resisters some months ago but never changed the 10k ones for 100K...
All done now and my word it's loud & still sounding ultra fine with the HD-650's...
Listening with Gusto!
Old 30th November 2012, 06:53 PM   #1697
MisterRogers is offline MisterRogers  United States
Can you say Audio?
Here's my cased up Wire SE-SE-SE-SE Balanced build. It's nothing close to what Stixx put together, but I'm happy with it. Ignore the knob; I'm having a bolivian rosewood one made to match the case side panels.
Old 1st December 2012, 05:25 PM   #1698
Stixx is offline Stixx  Germany
Stixx's Avatar
Nice build Mr. Rogers!
Very clean and classic... only the wiring inside can be improved some
How do you like the Khozmo attenuator? (I was thinking to use one in my built but then opted for minimal size.)
Old 1st December 2012, 05:30 PM   #1699
Can you say Audio?
Thanks mate! I'm open to suggestions re: wiring. I didn't pull down the shrink wrap or tie up the routing yet; still thinking about the wiring routing. Apart from keeping power lines from output and twisting power, what else should I be tending to?
I like the Khozmo - a lot. It steps quietly, and I really like the 48 steps. It is big though :-)
Old 2nd December 2012, 03:10 AM   #1700
CaféNoir is offline CaféNoir  France
Well done!
You shoud twist everything very tightly (not only power wires).
Also, I see the main power cables and the transformer are a bit too close to the attenuator. I would probably try to swap the position of the attenuator and the headphone output socket, if that is possible.
Also, your picture screams for a detailed comparison with the schiit mjolnir!
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 04:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 07:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 04:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 10:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 09:47 AM
Copyright ©1999-2017 diyAudio
