Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 22nd September 2012, 01:29 AM   #1621
jdkJake is offline jdkJake  United States
Originally Posted by MisterRogers View Post
Soon :-) I need to order another/smaller transfo. I'm embarassed to lift the hood before I tidy up.
I assume mull3t already hooked you up with the small but mighty Amveco 62043-P2S02?
-- jk --
Old 22nd September 2012, 01:33 AM   #1622
MisterRogers is offline MisterRogers  United States
Can you say Audio?
Good timing - I was just surfing threads trying to track down that transfo :-) I remembered that Mull3t spoke highly of it.
Old 27th September 2012, 10:13 PM   #1623
Mull3t is offline Mull3t  United States
I did indeed use the Amveco and have to give credit to jdkJake for that find.
MrR -- I think I recognize that case po1019 from eBay did a fantastic job with my case. I would buy from him again.
Old 27th September 2012, 10:22 PM   #1624
Can you say Audio?
My Amveco just landed; can't believe how much smaller it is. Yea, he really does do nice case work. I've bought 4 from him so far for various projects. my only 'nit' would the opening being on the bottom. It's not necessary to use it that way, but if you want seamless lines...
Old 27th September 2012, 10:31 PM   #1625
I believe his cases are designed to be tube amps hence everything is upside down. I decided to have him do all my drilling, etc. and have him flip everything. I don't mind not having the seamless lines. It still looks good.
Old 27th September 2012, 10:40 PM   #1626
Can you say Audio?
Yep, I think you're right. I did the same with the cases I bought from him for my DAC's (pre-drilled). For the cost - such a deal.
Old 28th September 2012, 03:01 PM   #1627
Can you say Audio?
Need a bit of help with the Amveco. So for 115, Red+Yellow to Neutral. Just not sure about the secondaries. I'm hooking them up to the Wire PS. I have Blue, Red, Brown & Green in order. Guys?
Old 28th September 2012, 03:09 PM   #1628
hochopeper is offline hochopeper  Australia
I've never used the Amveco transformers but digikey gives this diagram on the page for the model linked referred to by jdkJake earlier
http://media.digikey.com/pdf/Catalog...0SCHEMATIC.jpg
So keep the secondaries in the same order for each half of the PSU, the dot indicates the start of the winding.
IF that is the diagram that corresponds to your transformer then something like:
green-red, brown-blue
should do the trick. But your order seems different to what the diagram suggests. Is there a similar diagram stuck on the side of the transformer?
Old 28th September 2012, 03:20 PM   #1629
Can you say Audio?
Yea, that's it. Hmmm. I have Red+Yellow to Neutral, secondaries are paired as you indicated. Does it matter the order? (greed-red vs. red-green)? Get a loud hum when I power up.
Old 28th September 2012, 03:30 PM   #1630
Can you say Audio?
It's working. Ya know, old age sucks. I strain to see clearly and it burns me time and again. I didn't have both pins on the power connector. Thanks for your help mate.
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 04:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 07:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 04:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 10:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 09:47 AM
Copyright ©1999-2017 diyAudio
