Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 9th February 2012, 12:33 PM   #1421
BuildMeSomething is offline BuildMeSomething  United Kingdom
The Wire is certainly a very fine amp indeed, got say that I swapped op-amps and output caps on my source after logging about 50hrs on the Wire. Each change to the source has been clearly audioble, both good and bad... Super happy with the Wire
Was very tempted by the LPUHP amp, but the only spair speakers I have are 25W / 8Ohm... looking forward to whatever opc offers-up next.
Paul
Listening with Gusto!
Old 10th February 2012, 08:26 PM   #1422
TiEx is offline TiEx
TiEx's Avatar
Owen, can you post BAL-BAL measurements? I have shoveled the thread but found only BAL-SE and SE-SE. Just curious to see fully BAL.
Old 11th February 2012, 11:51 PM   #1423
IanAS is offline IanAS  England
What from and to?
Old 12th February 2012, 10:53 AM   #1424
Originally Posted by IanAS View Post
What from and to?
Op-amps: from JRC5532D to LME49720MA.
Electrolytic caps: from Elna Tonerex to Elna Silmic II, Cerafine and now Nichicon KZ.
Now wondering about bypassing the caps!? More research & questions to ask about this...
Anyway, it's all fun. I can disassemble, swap caps and rebuild the player in well under an hour now
Old 12th February 2012, 11:02 AM   #1425
hochopeper is offline hochopeper  Australia
I'm only just about to start procurement of parts for my bal-se but you might be interested in some of the posts in this thread from late Dec around this very issue - http://www.diyaudio.com/forums/headp...ml#post2838616
Old 12th February 2012, 11:30 AM   #1426
Cheers for the link, it answers part of my question
Was looking on LC Audio's site [XO3 clock] and they list other possible upgrades, bypassing the output caps being one. Looks easy enough to do & normally I ask the 'why & is it dangerous' bits after the doing part. This time I'd like to know what the bypass does [how & why it works] & can implementing it be harmfull, before doing the mod
Paul.
p.s. I wasn't looking to remove the caps [directly coupling the outputs?], but adding a bypass cap & resistor. Probably easier to directly couple the outputs though...
Old 12th February 2012, 02:55 PM   #1427
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Did you find anything left
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 14th February 2012, 08:12 AM   #1428
perfidoclone is offline perfidoclone  Italy
Hi Owen,
I'm interested about a complete kit for BAL-SE or BAL-BAL.
Thank you,
Matteo
Old 14th February 2012, 03:45 PM   #1429
qusp is offline qusp  Australia
qusp's Avatar
sigh
Old 14th February 2012, 10:29 PM   #1430
Default Unobtainium
Originally Posted by qusp View Post
sigh
I feel your pain...
IIRC, opc will be doing a tally of leftovers soon[ish] and will post-up what's left, if anything. Keep tuned and please be patient
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
Copyright ©1999-2017 diyAudio
