"The Wire" Ultra-High Performance Headphone Amplifier - PCB's - Page 75 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 29th September 2011, 01:01 PM   #741
Default OT: this is why I cannot use open headphones :-)
Taken in underground.
D.
Old 30th September 2011, 03:11 PM   #742
jtktam is offline jtktam  Canada
I want to pay.. when do i pay?
-joe
Old 30th September 2011, 03:22 PM   #743
heinz1 is offline heinz1  Europe
-joe
See post #695:
Originally Posted by opc View Post
Hi Guys,
No payments yet, as I still need to test all the boards on arrival.
Here's the schedule:
- GB closes Sunday September 25th (this Sunday)
- Place PCB order Monday September 26th
- Boards arrive two weeks later on Monday October 10th
- One week to assemble and test all variations brings us to October 21st
- Payments will start to be accepted October 21st and boards/kits will ship out the following week.
I hope that clarifies things!
Owen
Old 30th September 2011, 08:53 PM   #744
qusp is offline qusp  Australia
qusp's Avatar
what? in here too?
Old 3rd October 2011, 09:32 AM   #745
TzeYang is offline TzeYang  Malaysia
Hello, I'm curious about the design techniques used to design the PCB.
Is the PCB designed with a center ground plane or a star ground?
what is the power/signal/plan distribution like?
thanks.
EDIT: Also if this is not asking too much, can someone show me the square wave response of the amplifier?
THANKS!
Old 3rd October 2011, 11:12 PM   #746
Originally Posted by N-Brock View Post
Owen -
What are the dimensions of the PSU?
An image of the layout would be nice too.
Owen,
According to your schedule PCBs are now in production - could you please the finally specify board dimensions (with mounting holes location) and layout please?
rgds,
jacek
Old 5th October 2011, 02:28 AM   #747
Wolfsin is offline Wolfsin  United States
Anticipation iz makin'me . . . Short of working on a case there is little to do to cut the anxiety called forth by anticipation so, Jacek, if you need to build it now, just build it BIG :-)
I am eager to build it too. Everything iz procured, powsupp iz ready, so I lashed up a way to A-B compare the bal-bal to a pair of bridged LME49600 boards, each using a pair on the push and a pair on the pull. Thinking about test now iz a good way to get ready even if you expect, as I do, the null outcome. Also take the time to think thru the cabling now to avoid the last minute rush to that 'first listen'. When I first connected the bridging noted above I used blocking caps that, upon reflection, were not needed and misled me to an unwarranted disappointment.
Old 7th October 2011, 01:32 PM   #748
i hope in this coming design owen will allocate space to mounth the volume control on pcb
Old 7th October 2011, 02:19 PM   #749
by the way, if it's not too much of a trouble, i'd like to change my order to SE-SE PCB + PSU kit. thanks
Old 7th October 2011, 02:26 PM   #750
N Brock is offline N Brock  United States
N Brock's Avatar
The layout has already been posted (the se-se version anyways) in post #658.
No space for a pot it would seem.
Unless you are referring to something else?
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
Copyright ©1999-2017 diyAudio
