"The Wire" Ultra-High Performance Headphone Amplifier - PCB's - Page 183 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 9th March 2013, 01:18 AM   #1821
qusp is offline qusp  Australia
qusp's Avatar
yep, no doubt your choice of patterns has to do with habit at your day job and favorite libraries for that where better tools/reflow are more easily accessed.
also I meant rectifier above, not inductor, I had inductance on the brain. the 1210 cap regulator reference bypass and the bridge on the power supply boards I found the most challenging, as its compounded by the direct thermal connection to the solid ground and power planes.
how profoundly does the addition of thermal relief effect impedance at the currents/slewrate we are talking about? I ask this not just for this board, but the PCBs i'm currently working on use solid planes for everything including input and output. they will be reflowed most likely so not such a big deal, but just for curiosity.
Old 5th April 2013, 09:13 PM   #1822
Rubin is offline Rubin  Canada
Default Update on kit ETA
Hi. I'm one of the people who missed the original group buys who is eagerly anticipating the release of the new kits. Any update of when they will be available? Thanks!
Old 8th April 2013, 03:32 PM   #1823
I think there an outstanding number of lurkers who are eagerly awaiting another batch... (including me )
Still working on your website Owen ?
Old 11th April 2013, 03:26 AM   #1824
prezden is offline prezden  Canada
I would be interested in one
Old 3rd May 2013, 10:00 PM   #1825
clsidxxl's Avatar
Soon available again ? Thank.
Old 3rd May 2013, 10:14 PM   #1826
JBdV is offline JBdV  Netherlands
I want 2 ;-)
Old 15th May 2013, 10:13 PM   #1827
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I figured out this darn switch within my 'wire' is causing me grief.
It's a Defond 12A 115vac, it's wired up between iec inlet and my transformer.
Old 16th May 2013, 03:02 PM   #1828
This is how I wired up the switch...
I guess I should ground it to the case.
Old 16th May 2013, 03:40 PM   #1829
nattawa is offline nattawa  Canada
Is that the wiring that did not work? Was the bulb constantly lit regardless the switch position? If it was, you were using wrong pair of pins on the switch. Try the center pin and the one on the other side.
There could also be a safety issue with the wiring. You're supposed to put a switch following the Live terminal of the IEC socket, but it seemed in the diagram the switch is on the Neutral.
The ground pin of the IEC socket should be wired to the chassis.
Old 16th May 2013, 03:42 PM   #1830
The switch worked (neon bulb) lit when I pushed the rocker up (and off when down).
Just wasn't getting any ac to my transformer from the switch.
I guess I should be using neutral (black) to the switch.
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
Copyright ©1999-2017 diyAudio
