"The Wire" Ultra-High Performance Headphone Amplifier - PCB's - Page 181 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 6th March 2013, 03:20 AM   #1801
Thunau is offline Thunau  United States
Thunau's Avatar
Originally Posted by opc View Post
Yes...
It's in the works right now. I will be offering all variants in a new layout that is designed to fit in an extruded chassis.
I'll be offering bare PCBs, completely assembled PCBs, and likely a fully assembled product style version.
Stay tuned here for a link in the coming weeks.
Owen
Subscribing to the thread. Please post here first when you have some more kits or complete amps for sale.
"Most people just say what they know, the wise ones know just what to say."
Old 6th March 2013, 08:34 AM   #1802
JBdV is offline JBdV  Netherlands
Great Owen, this is what I have been waiting for all along ...
Old 7th March 2013, 12:31 AM   #1803
good news that there's to be more bits in the offering. It'd be gready of me to get more amps, however I'm certainly intrested in a DAC and am keeping a little aside just in case
Listening with Gusto!
Old 7th March 2013, 01:28 AM   #1804
opc is offline opc  Canada
opc's Avatar
Hi Guys,
Glad to hear the enthusiastic comments! As expected, all of this is a little more work than I anticipated, but things are progressing. I'm working on a website as we speak, and some board orders are starting to trickle in. I should know more in the next week or two.
Thanks for all the patience with this, and I'll be sure to let everyone know as soon as I'm ready to get things started
Owen
Old 7th March 2013, 01:36 AM   #1805
Nothing wrong with being greedy! If you get a new DAC, you'll almost certainly find yourself justifying the 'need' for a balanced input on your amps
It's not greedy when it is a necessity!!
No matter what, you'll have less amps than qusp :P
Under Construction:Ian's i2s FIFO wiki
Old 7th March 2013, 02:05 AM   #1806
Can you say Audio?
Thanks for the update Owen. Anxiously waiting :-)
Old 7th March 2013, 09:53 AM   #1807
LOL ... does anyone have more amps the qusp???
Was thinking the very same thing about balanced inputs. If a DAC is to offered, then surely it'll be ballanced output giving the need for a balanced headphone amp to match it. Furthermore, a second balanced unit to act as a pre-amp for the Power Amp, which can be simply changed into recieving a balanced input. Conluding, 1 x dac and 2 x bal-bal amps ... No pressure Owen
Old 7th March 2013, 10:00 AM   #1808
qusp is offline qusp  Australia
qusp's Avatar
what makes you think you need a preamp? better to just install a decent ADC in front of the dac IMO.
haha you need look no further than the pages of the Pass Labs forum to find people with many more amps than I
Old 7th March 2013, 01:20 PM   #1809
Zsubbo is offline Zsubbo  Hungary
Can I have a silly question about the balanced wire amps ?
Can I use it in SE mode ?, like at the balanced DACs ? I mean only using the positive half of each channel ? I know that you can use the balanced bridged amps like that, like the headamp GS-X.
Old 7th March 2013, 03:27 PM   #1810
opc's Avatar
You certainly could, but you may need to solder a 10k resistor in parallel with the cap on the VCOM pin to ensure the output common mode voltage is 0.
If you do that, then there's no reason you can't take a single phase of the output (with reference to GND) to drive a pair of headphones.
You should definitely not ground the unused output however, as that would be the equivalent to a dead short for the buffer.
This arrangement will have higher distortion and noise, so I would instead suggest the use of a BAL-SE or SE-SE amp
Owen
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 04:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 07:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 04:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 10:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 09:47 AM
Copyright ©1999-2017 diyAudio
