"The Wire" Ultra-High Performance Headphone Amplifier - PCB's - Page 176 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 22nd January 2013, 03:29 PM   #1751
Can you say Audio?
heh. Yea, caught that too. The world needs more "Wire' Owen - one way or another :-)
Old 22nd January 2013, 03:44 PM   #1752
IanAS is offline IanAS  England
What would be nice is if a DAC chip were butted up to the headphone amp chips. With IS input. So I can wire my CMedia DSP, with cross feed, into it and therefore delete analogue interconnect and all the degradation that come with it. A pal tried this with 0.5 metre and 5 metres of cheap microphone cable and could hear no difference.
I'd then want to extrapolate this to having the DAC and amps on the headphone head band with long IS and long DC voltage wires. Thereby deleting the speakers cables and all the degradation that come with it.
But what DAC chip, etc.
I'm thinking of an AK4396 as they are about 5 and available and sound not too bad and have a balanced output to go into the balanced input.
Old 25th January 2013, 05:12 AM   #1753
qusp is offline qusp  Australia
qusp's Avatar
yeah because signal integrity in long i2s wiring and long low level DC is so much more robust than long analogue interconnects....
(i2s is designed to travel mm between chips on the same PCB, it has no CMRR, it has no error correction at all)
the AKM is a decent choice though, or perhaps the es9016 and modify 'the wire' to have suitable IV resistors. thats what I did with my 'portable' ES9018 + the wire BAL-BAL
the wire is under the blue reg/battery manager/volume control/toslink+BNC input comparator/mcu PCB. It is wired directly to the es9018 dac outputs with ASMP SMD Zfoil IV resistors on 'the wire'
you can see the bling stranded UPOCC silver twisted pair outputs to a Lemo 4 pin, I do have a few long held irrational beliefs left that arent going away any time soon. I still believe in OTT build quality, magic not so much.
File Type: jpg portable es9018 w bal jh13_05Nov2012_1376.jpg (219.9 KB, 552 views)
File Type: jpg in temporary case but done_05Nov2012_1362.jpg (266.3 KB, 550 views)
Old 25th January 2013, 08:29 AM   #1754
It's found going much further. The 1980's Philips players had it going from board to board via multiple plugs and sockets and wires. The DAC Magic that I have I think it might be the IS that being fiddled with to create a compliment, then going through multiple vias over about 6 inches.
It may or may not be ideal but analogue wire are certainly not.
When I say that a pal tried it, what I mean is that in the '90's, as a business, he was making and selling outboard PSU's with a long IS umbilical to discerning customers. And not cheap either. It was working well enough.
I might like to use those ESS chips but I can't stretch to the expense at this time. And if I recall correctly I don't like the Buffalo boards, the layout seemed messy with so many other sub board needed. And the price...
Having said that, I just saw this post saying he has a "DIY USB DAC based on the ES9023 Sabre DAC and it only cost me 25" http://www.whathifi.com/forum/dacs/a...-dragonfly-dac
A friend just bought the Audioquest Dragonfly DAC I've not really heard it.
Old 25th January 2013, 10:15 PM   #1755
Here's a thread about that tiny Sabre USB DAC: An USB ESS sabre DAC
Old 25th January 2013, 10:30 PM   #1756
qusp's Avatar
anywhere its found going much further without some sort of reclocking stage is likely to cause at least as much distortion as analogue interconnects, which have only anecdotal distortion at these levels if properly made. it was not designed to be used like that, but of course people still make stupid design decisions
yeah ive seen that dragonfly thing, honestly the marketing department has a lot to answer for, they make a number of ******** impossible claims, particularly about the volume control and headphone amp sections.
re buffalo I know what you mean and agree for the most part, but as you can see i've used only one small dac module. it all went a bit crazy after the buffalo II and some of the tangled messes people called dacs with the BIII are nuts. it would be difficult or impossible to do what I did above with the BIII or even BIIISE rather than the BII
Old 29th January 2013, 02:51 PM   #1757
Originally Posted by opc View Post
Hi Emphrygian,
Sorry for the delay... I just checked the layout and both inputs and outputs on the PSU are spaced at 0.125".
They were intended to have wires soldered directly to the pads, so I'm not sure if they make connectors with that pitch. Next time I'll opt for a more standard spacing if there is room.
Owen
Thanks for checking.
It does indeed seem like there are no .125'' terminal blocks at Digikey and I can't be bothered to investigate more, it's not that big a deal. I'll just solder the wires directly to the pads, like you intended.
I had sort of figured I had to do this anyway, since a block would likely not fit with respect to the closeness of the ouput caps (unless I mount them on the back). Blocks on the input would have been nice, but as I said, no big deal.
Old 29th January 2013, 03:23 PM   #1758
qusp's Avatar
not a huge fan of blocks myself, never use them except sometimes on power supplies. for signal CMRR is more important to me than having a block, if it needs to be able to be disconnected I put an inline connector.
Old 29th January 2013, 04:05 PM   #1759
I would never consider blocks for signals, only on voltage regs and such. Helps a lot if you want to try out different ones =)
Old 29th January 2013, 05:19 PM   #1760
qusp's Avatar
yeah I tend to still hardwire, or initially hardwire a dongle type connector on a cable, if its going to stay I just desolder or snip off the connector and solder it.
I mentioned it mainly since we see so many of those things for signal, I really dont get it.
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
Copyright 1999-2017 diyAudio
